Previous in Forum: Painting ULSD Tanks   Next in Forum: Used Engine Oil
Good Answers: 18
Sorel Cement
05/27/2009 10:12 AM
I am looking for information on the process for production of sorel cement. I checked on Wiki with no luck. Does anyone on CR4 have experience with manufacture of this material?
Re: Sorel Cement
05/27/2009 11:23 AM
Good Answers: 18
Re: Sorel Cement
05/27/2009 11:14 PM
Thanks John. It looks like a good starting point as it also references some other patents and literature.
Good Answers: 68
Re: Sorel Cement
05/28/2009 8:15 AM
Hello aqua doc,
Check out the list of sites which explain how 'sorel cement' is made........... Ignore the Invention sites, just look at the sites of companies making sorel cement'
http://www.google.com/search?client=safari&rls=en-us&q=process+for+production+of+sorel+cement.&ie=UTF-8&oe=UTF-8
bb
Good Answers: 68
Re: Sorel Cement
05/28/2009 8:27 AM
Hello aqua doc,
Check this out.
http://www.nedmag.nl/index.php?option=com_content&task=view&id=148&Itemid=363
Preconcentration of U(VI) from aqueous solutions after sorption using Sorel's cement in dynamic mode Journal Journal of Radioanalytical and Nuclear Chemistry Publisher Akadémiai Kiadó, co-published with Springer Science+Business Media B.V., Formerly Kluwer Academic Publishers B.V. ISSN 0236-5731 (Print) 1588-2780 (Online) Issue Volume 264, Number 3 / May, 2005 DOI 10.1007/s10967-005-0762-1 Pages 623-628
Subject Collection Chemistry and Materials Science SpringerLink Date Friday, May 20, 2005 Add to marked items Add to shopping cart Add to saved items Permissions & Reprints Recommend this article PDF (1.1 MB)Free Preview N. S. Awwad1 and A. A. M. Daifullah2
(1) Hot Labs. Centre, Atomic Energy Authority, P.O. 13759, Cairo, Egypt
(2) Hot Labs. Centre, Atomic Energy Authority, P.O. 13759, Cairo, Egypt
Summary Mg(OH)2 was identified as a component of Sorel's cement being a very strong sorbent for uranium. Sorel's cement is a mixture of MgO, MgCl2 and water. The optimal conditions for the adsorption of U(VI) was studied by the batch method. A contact time of 2 hours was found to be optimum.
Maximum U(VI) uptake was observed in a pH range of 5.5-6.5 with a sorption constant of Kads = 0.9 h-1 at initial concentration of 20 ppm.
Polypropylene columns filled with 2 g of Sorel's cement at a mesh size of 35 were used for the preconcentration of uranium by passing 8 l of water containing 10 ppb U(VI). A flow rate of 0.25 ml/min and a bed height of 5 cm were found to be the optimum for the U(VI) separation.
A 5 wt% triphenylphosphine oxide solution in toluene was used as an organic solvent for the separation of uranium from interfering elements such as iron(III) and thorium(IV), prior to spectrophotometric analysis. The determination of U(VI) was accomplished by adding Arsenazo III as a coloring reagent to the solution and using a UV-160A spectrophotometer
bb
Re: Sorel Cement
09/28/2011 4:44 PM
I spent quite long periods of frustrating attempts to make the process to give good results, reproducible results, it was tricky as all things are. How ever it is very practical and useful for making so many nice things using Sorel cement. Now what do you want the process for ? will you let me know.
Re: Sorel Cement
09/28/2011 9:08 PM
hello masoud Kowsar,
i was wondering where in the world you are? i tried to send you a personal message, but there was no link at your profile. thank you artbyjoe
Register to Reply 6 comments
agua_doc (1); artbyjoe (1); babybear (2); JohnDG (1); masoud Kowsar (1)
