Previous in Forum: laser yag rod   Next in Forum: M.Tech Electronics&Telecommunications
Electrical Faults in High Voltage Transmission Systems
05/28/2009 11:08 AM
Hi, I'm a student , can some answer me giving specific details and examples on what causes electrical faults on a High Voltage Transmission System?
What over current protective components can be used in a high Voltage transmission system?
What advantages are there in putting a capacitor as close as possible to the terminals of a motor to correct power factor?
Re: Electrical Faults in High Voltage Transmission Systems
05/28/2009 7:52 PM
First, read the FAQ about homework.
Good Answers: 101
06/02/2009 2:19 AM
"First, read the FAQ about homework".
Second, read your textbooks.
Third, visit the library.
Fourth, since you appear to know how to use the Internet, please allow me to introduce you to a little thing called "Google", which you can access via the following address: http://www.google.com/
Fifth, ask your teacher for advice after gathering and analyzing all your data if there is anything you don't understand.
What, did you think either Obi-Wan or Lord Sidious allowed me to get other people to do my homework for me when they taught me the Ways of the Force ?!
