Dear members of CR4,
I'm an engineering student working as a trainee. I'm working on a project to design and construct an optical bench for measuring different properties of ccd- objectives:
- degree and kind of distortion
- resolution of the objectives for different magnification
- brightness declension of the objective from centre to the edge of the lenses
- Measuring the focal length of the objective….
- Etc.
So far I almost can measure all the properties, using my Optical bench in a good accuracy, beside the focal length.
How can I measure a focal length of an objective (with mount), with out knowing the position of the main Plane?
I have tried to use the Bessel method it doesn't work for objectives with focal length smaller than 20 mm (Its good for singlets) because of the mount. My objectives have a focal length (fixed) of 4,6,12 and 16mm. And I also tried to calculate the focal-length form the object –image distance and the magnification. The result is not good (5-15% inaccuracy). "Here may be I need a complicated correction factor!"
Could you please give me a tip how to solve this problem without using complicated methods?
