Have a profibus installation where the cable has come from the processor to a module block. All connection to devices has been made by using jumper bars at the module block, rather the daisy chaining to each device. Profi trace shows collisions of data from each device but the system currently works. Will we need to wire the devices correctly with the correct termination resistor? I belive if the problem is not sorted now there will be problems in the future
