pulleys and ratio ,power.If you had a 14 inch pulley on the motor shaft,[motor is 1 hp] and a 2 inch pulley on a generator shaft and it reaches will say 50 rpm. and make will say 30 volts at 10 amps. I just put in all the figures that i could think of.Their just examples to use. My question is if I "increased BOTH pulleys to be the SAME ratio would all out put stay the same/or would it be easier . I know that If I just change the small pulley that it would take Less power from the motor.A friend and I were talking about this.Its about a wind turbine. I have the 14 inch pulley on the mail shaft and a 1 1/2 pulley on the alternator.It only have to do 2 rpm to reach 12 volts.
Lot of fun.
Thanks to all .in adv.
Johnny
