Previous in Forum: Flexible joint for Centrifugal Pump   Next in Forum: theory
what is engine rigging testing?
06/06/2009 1:15 AM
engine testing rigging is used to test the engine for its performance?
It is used to check the enine against various defaults like air leakage , water leakage.
how we will mount the engine on conveyor And various accessories required for testing
Pathfinder Tags: engine rigging
Re: what is engine rigging testing?
06/06/2009 2:36 PM
ANSWER: Yes.
ANSWER: Yes, can be used for this purpose too.
ANSWER: Depends on your test setup and engine. These things are normally designed to fit each other.
Humm... suspicious you are...
