Previous in Forum: Current imbalance 3 phase motor   Next in Forum: KVA of UPS
Plant Load for Electric Power Plant
06/06/2009 1:54 PM
I want to know the basics for calculating the electrical load of water pumping stations running with star delta motors on 220, 11 kv and 3.3 kv electric supply.
Similarly, the electric load of water filtration plant will also be required. I will need a stepwise method for calculating these electric load with safety measures.
Re: Plant Load for Electric Power Plant
06/06/2009 4:25 PM
Add up all of the motor HP. Add up the rest of the stuff. Total.
07/23/2010 8:01 AM
Baseload plant, (also baseload power plant or base load power station) is an energy plant devoted to the production of baseload supply. Baseload plants are the production facilities used to meet some or all of a given region's continuous energy demand, and produce energy at a constant rate, usually at a low cost relative to other production facilities available to the system. Examples of baseload plants using nonrenewable fuels include nuclear and coal-fired plants.
technical-consulting-services
06/08/2009 12:15 AM
You should first get a flow diagram from the concerned process engineer or develop yourselves. From design parameters you can estimate the power requirements. If difficult, leave the work for professionals. Power of utilities for the water pumping plant and water filtration plant also need to be estimated. Otherwise you will be short of modules in MCC.
09/04/2010 1:09 AM
HI,
Electric Generation Using Natural Gas
Source: Sandia National Libraries
Natural gas, because of its clean burning nature, has become a very popular fuel for the generation of electricity. In the 1970's and 80's, the choices for most electric utility generators were large coal or nuclear powered plants; but, due to economic, environmental, and technological changes, natural gas has become the fuel of choice for new power plants. In fact, in 2000, 23,453 MW (megawatts) of new electric capacity was added in the U.S. Of this, almost 95 percent, or 22,238 MW were natural gas fired additions.
[url=http://www.sterling-energy.com]Technical Consulting Services[/url]
Register to Reply 4 comments
angelina (1); b v rao (1); Trincypris12 (1); wareagle (1)
