Previous in Forum: Solar Energy Calculations   Next in Forum: Cable Shielding Rules
8 comments
Battery-Operated Controller for Gravity Fed Irrigation
06/07/2009 1:28 PM
would a battery operated irrigation controller with built-in solenoid (latching type) using button batteries for data and 9v battery for switching selenoid,be ok for gravity fed irrigation? I believe most selonoids use water pressure to help activation.for what its worth battery controllers all use latching solenoids.
Re: irrigation,controller with selenoid
06/07/2009 3:33 PM
I would have to say probably no from an electrical point of view as standard 9V (PP3 format) batteries are not designed for powering the high currents necessary to operate a moderately-sized solenoid. Do you know what the solenoid voltage and current ratings are?
06/07/2009 4:13 PM
Yes, I have designed a commercial product which is used in drain dosing applictions, using gravity feed, a latching solenoid and 4 C cells, bettery life exceeds 2 years for a daily shot.
I can give you some technical details/help/info, but obviously not the full juice.
The key is finding a microcontroller (or control electronics, which will work at a suitable voltage 6-4v in my case while drawing very little quiescent current, and a solenoid which will also work at that voltage)
It's the quiescent current which kills battery products, (that's the current it is drawing all the time 24 hours a day...) I've seen several manufacturers claim ludicrous battery life because they've forgotten to add in the quiescent current and have only looked at the pumping/dosing current.
06/07/2009 5:10 PM
Aren't you clever!!!!!!!!!!
06/07/2009 5:14 PM
aw shucks... I do screw up a lot too.
Good Answers: 18
06/08/2009 11:29 AM
Could such a unit be solar-powered for use in arid conditions in the third world on drip irrigation?
06/08/2009 12:59 PM
Yeah, you could use solar charged re-chargeable.
Bear in mind it's a gravity delivery system, so you'd still have to get the water 'up' some how.
Re: Battery-Operated Controller for Gravity Fed Irrigation
06/08/2009 3:05 PM
see this link for what i have in mind,also latching selenoid used only in battery operated controllers dont use any power to hold back the solenoid (hence advertisers claim battery lasts one season) but the question remains can i use this unit with a gravity fed drip irrigation system,or does the solenoid need pressure to actuate,cheers
http://www.javelinirrigation.co.uk/html/Turf_Products/turf_products/olympic_2000.htm
06/09/2009 7:01 AM
Why use electricity at all? The Flout dosing device is used to turn on and off water flow based solely on the water height in a tank. Add a gravity powered sequencing valve (say four outlets) and the same equipment could irrigate a number of areas.
Check this link for sequencing Flouts...
http://www.youtube.com/watch?v=9uGNocD0weg&feature=channel_page
And this one for an un-powered sequencing valve...
http://www.youtube.com/watch?v=YDtzdtJjOeA&feature=channel
Send me any questions.
If I hear hoofbeats, why don't I ever think a Zebra might be around?
Register to Reply 8 comments
agua_doc (1); jack of all trades (1); lyn (1); Sparkchaser (1); streetmason (1); user-deleted-1105 (3)
You might be interested in: Battery Holders, Battery and Fuel Cell Components
