Previous in Forum: tail of an aeroplane   Next in Forum: Hydraulic Cylinder Repair Kits
Caterpillar Engines 3512B AND 3508B
11/30/2006 4:19 AM
2 CAT ENGINES - 3512B - SER.NO. 2GW00359 - ARR.NO.: 1809193
AND
3508B - SER.NO. 3DM00340 - ARR.NO. : 1736952
MY QUESTIONS ARE
ARE THE FUEL INJECTORS THE SAME ? AND HAVE THEY THE SAME SPECIFICATIONS?
AND CAN I USE THE SAME TYPE FOR BOTH ?
United States - Member - Germany - Member - Spain - Member - Trabajo en Pamplona
Re: caterpillar engines 3512B AND 3508B
11/30/2006 7:39 AM
It might not hurt to give these guys a call....
http://www.bostonfuelinjection.com/bficat.htm
otherwise- Give CAT a call.
Re: Caterpillar Engines 3512B AND 3508B
12/01/2006 12:50 AM
Yes absolutely. Just make sure you add a tea-spoon of sugar.
Engineering Fields - Piping Design Engineering - New Member Technical Fields - Architecture - New Member
12/01/2006 1:18 AM
Dear friend
I am an ex Caterpillar engineer i would recamend you get in tuch with your nearest Catpillar dealer who has access to CAT Tichinical web site,(and Thechnical information of all parts going in to the engine will be maintained by serial number of the engine by Caterpillar, accessable only by dealer and select emplyeeyes of Caterpillar) and give you right answer.It will not take more than one minute to serch the deatils you are looking for.and this web site is password protected by Caterpillar.
Run silent run deep
12/01/2006 9:37 AM
No, The 3512 is a 1100hp @ 1200 rpm marine Propulsion Engine, The 3508 is a 600kw @ 1500 rpm generator set engine.
The injectors are different part #'s and have different fuel delivery rates based on HP requirements.
Why would you want to interchange them?
CAT Reman injectors 10R1284 cost is $664.89ea. for the 3512
and 10R1288 cost is $ 664.89ea. for the 3508
Register to Reply 4 comments
Anonymous Poster (1); Bearcat 2 (1); crm (1); stilljester (1)
