Previous in Forum: Relay Contacts and Arc Protection   Next in Forum: Generator Frequency
IC Design
06/10/2009 3:42 PM
Please help me to design an IC using flow diagram which will perform the following equation considering three different resistor
Output:
pin1 : Vr1= (R1*Vs)/(R1+R2+R3)
pin2 : Vr2=(R2*Vs)/(R1+R2+R3)
pin3 : Vr3=(R3*Vs)/(R1+R2+R3)
where R1, R2 and R3 are not equal
Needed: 1. Flow diagram
2. Process Design Diagram
3. Circuit Design
4. etc.
Pathfinder Tags: IC
This discussion was "closed" on 06/10/2009 4:19 PM. No new comments are allowed.
Message from admins:
CR4 is not a homework cheat site.
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
Re: IC Design
06/10/2009 3:53 PM
Is this a homework problem, salmandk?
Re: IC Design
06/10/2009 4:07 PM
No brother. This is a part of my class lecture
Friend of CR4
Re: IC Design
06/10/2009 4:09 PM
Are you teaching the class or is this an assignment that you need to complete?
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
Re: IC Design
06/10/2009 4:16 PM
This is a part of assignment. Please give this answer early. It is emergency
Friend of CR4
Re: IC Design
06/10/2009 4:18 PM
Sorry, CR4 is not a homework cheat site.
Chris Leonard (2); salmandk (2); Steve Melito (1)
