Previous in Forum: Thrre-phase hybrid active power filter   Next in Forum: Touching a HT Line
How to wire GFCI recepticle with non GFCI recepticles
06/15/2009 3:22 AM
I have got a GFCI recepticle and 4 normal recepticle outlet. How do i wiring up the GFCI type with the others recepticle.?
There's line' and load' point on the GFCI recepticle what is it use for?
Cheers!
Good Answers: 73
Re: How to wire GFCI receptacle with non GFCI receptacles
06/15/2009 10:35 AM
The power feed is connected to the terminals marked as 'line'. If this is in the USA, then your white wire should be your neutral and it connects to the terminal closest to the largest slot (found on the front side). The hot is usually black, and it connects to the terminal with the smaller slot. You can connect the ground wires together with a wire nut and then attach a single ground wire to the ground lug.
The 'load' connection is for a line that powers any other receptacles that you wish to protect. You must observe and maintain the black, white, and ground pattern as described.
By all means, disconnect the circuit before wiring. Make sure it is really off before you begin. Truly, it is worth while to take proper precautions.
Reply to Forum Thread
