Previous in Forum: Crushing Hard, Iron-Base Lumps into Fine Powder   Next in Forum: Purity of Gold
10 comments
Materials for a Steam Autoclave
12/01/2006 10:18 PM
i m study bout the material selection for steam autoclave used to sterelize the lab or dental apparatus.the pressure applied is 2.1 bar and the temperature achive 121 degree C.anyone have an idea bout the design consideraation,safety factor,material selection and also the information related.
thank you.
United States - Member - Germany - Member - Spain - Member - Trabajo en Pamplona
Re: material selection for dental sterilizer(steam sterilizer))
12/01/2006 10:54 PM
For a material I'd say it probably needs to be made out of a Stainless Steel
12/02/2006 11:26 AM
how about cast aluminium?is it suitable to hold the pressure and the high tempurature.........
12/04/2006 7:37 AM
I'd stick with stainless - for medical purposes. Any sort corrosion is unacceptable for this type of application I'd imagine
02/22/2007 2:42 AM
i prefer to use stainless steel material for steam sterilizer
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
Re: Materials for a Steam Autoclave
12/02/2006 8:00 AM
Check out some of the web sites of companies that supply steam autoclaves. They may provide some of the information that you're looking for.
12/02/2006 11:00 PM
Is this a school exercise/project or are you reinventing the wheel? What size or capacity?
It will be a pressure vessel and local jurisdiction may require that it be built to meet code.
Autoclaves are available commercially for Steam or Electrical operation.
Good Answers: 120
12/03/2006 12:46 AM
Aluminum is to be avoided as it can corrode and is costly. Stainless steel or glass lined tanks are often used for this.
As someone said, get a boiler code book, it tells all.
Per Ardua Ad Astra
12/03/2006 5:45 PM
yes,i m doing my final year project.i wanna design n manufacture an autoclave for hospital application.the portable one.actually wanna built baisc skill regarding the mechanical n electrical part.the capacity is 0.040m cubic
thank you
Good Answers: 120
12/04/2006 8:15 AM
is this a dry or wet autoclave? A dry one is low pressure, just heated dry air. A wet one is high pressure steam at 120C or more and needs to be very strongly made with dual safety valves for over pressure.
Per Ardua Ad Astra
12/04/2006 8:44 AM
i ll design for the wet one.this is because the parameter for sterilization is 121 degreeC and 2.1 bar.So with wet one,i can get the high pressure.
thank you.
Register to Reply 10 comments
Anonymous Poster (1); aurizon (2); matmean (3); Steve Melito (1); stilljester (2); Stirling Stan (1)
