Previous in Forum: Pressure Compensated Vs Load Sensing   Next in Forum: need to ad merkblatter & trbs (group iv ) in english
8 comments
Compressed Air Calculation
06/21/2009 2:20 AM
Please let me know how to calculate the air consumption for following scenario:
In a tank of 400 ltrs a product is entered with sp. gravity of 1.56. The constant pressure of air on a tank is 3.5 bar which enters through pressure regulator and maintained at 3.5 bar throughout. even while product is getting consumed and than again refilled.
Re: Compressed Air Calculation
06/21/2009 9:23 AM
What is the products flow ?
It's pressure.?
I assume it is refilled under the 3.5 bar
It could be the product flow in volumen by 3.5 .
devitg
06/21/2009 11:42 AM
The product flow is 50 kg/min
and it's pressure is 12 bar
06/21/2009 1:24 PM
So the tank is closed , under 3.5 bar
Each time you refill , 50 kg/min * 1/ 1.56 kg /liter = 32.5 liters/min enters the tank.
What is the outcoming flow?
devitg
06/21/2009 11:45 PM
Outgoing flow is 40 kg/min.
06/22/2009 3:11 AM
The outgoing flow is 50 kg/min
06/22/2009 6:45 AM
If incomimg is at the same outcoming , no air spent.
devitg
06/22/2009 11:32 PM
In some cases product flow varies to 40 kg/min and air is getting escaped thru exhaust port.
06/21/2009 11:58 PM
Its depend on your consumption volum you need to study what is your consumption like you use 100 x100 size cyl double acting cyl so study which CFM requir that cyl then go to your compressure output CFM then calculate loading & unloading time of compressure
Register to Reply 8 comments
Anonymous Poster (1); devitg (3); munish_prashar (4)
You might be interested in: Bar Code Software, Bar Code Cards, Bar Code Scanners
