Previous in Forum: AC RMS and DC Calculation   Next in Forum: Air Conditioner Capacitor Voltage Rating?
Electrical System Failures
06/23/2009 10:32 AM
Why is it that mostly the "live" side of a connection is the one that breaks down, compared to the neutral? This happens in scenarious such as a geyser connection, plug top, etc.
Manfredh
Good Answers: 103
Re: Material break down
06/23/2009 12:15 PM
The break down is due to insulation failure ?
The insulation will fail when the b/d voltage of the insulation is less than the applied voltage ?
Now which side the applied voltage (with reference to earth) is more ? live side or the neutral side?
06/23/2009 1:17 PM
Simply put, I think, what gets used most wears faster and more frequently. Look at what has more "activity".
CARPE CRUSTULORUM!
06/23/2009 3:50 PM
The grid system will always fail at the weakest point, and for the transmission and distribution cable system that would be the joints (unless the pole is hit by a car or tree for example, in which case the joints will probably still be the mechanical failure point).
Good Answers: 16
Re: Electrical System Failures
06/23/2009 5:22 PM
Live side subject to galvanic corrosion? Thermal/fatigue stress due to power surges?
Just t'inkin.
De gustibus non est dispudandum.
06/24/2009 10:03 AM
This almost seems to obvious to state, but since the neutral often has an electrical connection to earth, in a non-fault condition neutral has little to no voltage difference to most of its surroundings. While the "live" side has the full potential difference to its surroundings.
06/24/2009 11:58 AM
In addition to what RedFred has said Voltage can be supplied Line to Line or Line to Neutral. Since the Neutral is the return path for current by breakering the line the circuit is open.
Register to Reply 6 comments
Apps Man (1); jack of all trades (1); not so smart (1); redfred (1); sb (1); Tippycanoe (1)
You might be interested in: Neutral Density Filters, Live Centers, Plug Valves
