Previous in Forum: Speaker Enclosure Design   Next in Forum: Dust Sensors
Speed measurement using LASER
12/05/2006 12:16 AM
I want to measure speed upto 200KM/Hr. I have all that sensors but slight change in source position or reciver position may allways showing some errors. How can I fix this error....
Every Problem has its own solution
Re: Speed measurement using LASER
12/05/2006 11:36 PM
Are you looking across the path and watching the object go by or are you pointing a laser at the object and getting a speed from the reflection?
12/06/2006 10:04 AM
If the object is moving toward/away from you, is the path at the same angle to you at all times? How large is the object? What's the composition of the object and its mass? Does it have surfaces that are normal (perpendicular) to the path of travel to help with laser reflections? How accurate do you need to be? In our small town, the local police department kindly offered to bring their laser unit to try measuring moving film speeds at our plant. This might be an option for you also.
12/09/2006 11:51 PM
hi,
i am suresh. i am studing eee. i would like to learn more about elecetical and electroic. but cant know how to increase my knowedge.so could u help me
i want some small projects.from that i have increase my knowedge.
Register to Reply 3 comments
