Hi everyone,
Thank you foy your attention,
This is the question:
I have to design a By Pass conical derivation from a 3700mm diameter pressure pipe (Pd: 323psi). The smallest end of the cone has 2400mm diameter, and the wall angle of the cone is 8°.
Regrding this, the size of the hole (apperturance) in the 3700mm pipe is approx 3200mm.
So:
ASME Code is allowed to calculate the reinforcement of the hole? Is it another method to calculate / design it?
Engineering Steel Plate Volume 4 has something related, but geometrical limits are exceeded in this case.
If more information is needed, please let me know it.
Any suggestion / help on this will be preciated.
Thank you in advance.
