Previous in Forum: Grundfos Pump 200x150x500 serial no 993532/2 Model;2RSKG4 Imeller size 510mm   Next in Forum: Fuel Pipe Sizes
Location: kibbutz nir-david, a beautiful rural village in Israel
Bicycle Gear Modifications
07/05/2009 3:55 PM
Dear friends
A month ago I bought a mt.pedelec-it is a mt.bike with an electric motor,since though I'm 71 yrs old I want to continue to bike up mt.Gilboa [its the next mountain to my home were king saul fought the Filistians and was killed], I want to be able to climb with the pedelec as high as possible before the batteriy will be emptied.The more I use my muscles power the higher I can climb.
BUT-the pedelec has only 7 speed, so the lowest gear is too fast for me and I'm getting tired after about 200m' vertical climb,so I'm seeking for a solution that will enable to bike up slower.
Is there any possibility to combine the chain bicycle's gear with an internal planetary in the rear wheel?
I was told that there is no practical way to have in the pedelec more than one sprocket where the pedals are.
Or is there any available solution to have more speed variations?
Re: Bicycle Gear
07/05/2009 8:00 PM
As long as I could check out in the pedelec, the electric motor is embedded in the rear wheel hub (some are in the front wheel hub). So, I'm affraid it would not be practical or economically feasible to include a reduction gearbox to the electric motor. But I think you could really change your chain transmission to a more reduced one by changing the front gear (not installing an additional one, but replace the existing one by a smaller - I did something like this in a bike of mine some years ago when I used to be a hard biker: I drilled out 4 rivets, removed the original gear, and in that case installed a bigger one held in place by bolts - because it was a custom hand made speeder/roadster). One bike shop near you could do the job, or just sell you the parts you need. But keep in mind that when you reduce your gears, its more likely (at least to me) that your electric power will last less. You'll be reducing your stress, but the electric motor will continue to try to put you up. Maybe you'll have to control the throttle more softly to avoid ending in a lower level than when you started. If your pedelec has a pedal sensor to dose the power, maybe it would work just fine. Another good way to gain some more meters up would be to ride it "manually" as long as you can, and then turn on the power to help you when things start to go bad. Specially usefull for when you climb to higher levels and start tryingto breath and seems the air is too thick to go in and out of the lungs quick enough... hehehe. By the way, here in Brazil we don't see those pedelecs... looks nice in the photos.
Humm... suspicious you are...
Good Answers: 145
Re: Bicycle Gear
07/05/2009 9:45 PM
Not in response to the gear issue, but getting more time before your batteries go dead seems to be an issue for you. If the battery is lead acid then you could probably parallel CHARGED batteries to give you more time. I don't know what the bike or battery looks like, but if there is a basket or room for a bracket then this is a modification to consider. Note that whatever charging circuitry you are using will probably be very unhappy if you try to charge a larger bank of batteries than it was intended to charge.
Don't do this without reading, asking questions, etc. and understanding about the battery life, battery SAFETY and charger characteristics.
Re: Bicycle Gear
07/06/2009 3:16 AM
I don't know about motorised (push) bikes but with racing (push) bikes you can normally get different gear sets for different terrains. So you would get a set for normal terrain with a high speed increasing ratio and a set for mountain climbing with a low speed increasing ratio (maybe even upto 1:1). You can remove and replace the gears from the set with a special tool (for the rear gears). You can get these gears from any specialist bicycle shop.
'There is no such thing as a silly question, only silly answers' - Unknown
Re: Bicycle Gear Modifications
07/06/2009 6:44 PM
Perhaps experiment with a change in the wheel size. This will effectively change the effort you must exert at each gear ratio - smaller wheels less effort, larger wheels more effort.
I cannot look at the leaf of a tree without being crushed by the universe. --Jules Renard
07/08/2009 1:59 PM
Here's a forum about them: http://www.pedelecs.co.uk/forum/electric-bicycles/
They may be able to help.
bhrescobar (1); BruceFlorida (1); corelite (1); DGCYS (1); Dutchy (1)
