Previous in Forum: Structural Analysis   Next in Forum: Soil Friction
Platform Weight Limit
07/06/2009 9:56 PM
Hi guys,
Can someone tell me what is involved in calculating the weight load limit of a wooden framed platform? I have a 25' x 8.5' platform constructed out of pressure treated 2x4s at 16" off center and a 3/4 plywood decking. The platform is anchored into a block wall on both sides of the 25' leaving a 8.5' unsupported span.
I have tried the usual google and CR4 searches but must not know some of the correct terminology for what I am searching for. Does anyone have a good resource or can give me some formulas to play with to calculate the maximum safe load limit?
Re: Platform Weight Limit
07/06/2009 10:14 PM
Correction, 2x6s, not 2x4s.
07/07/2009 12:41 AM
07/07/2009 11:42 PM
I used one of the online resource links from the awc to find the span table with the appropriate #/ft^2 which happened to be 50 #/ft^2. I multiplied that by the square footage and then divided by a safety factor of 1.5.
Then I subtracted the weight of the decking, railing, and other items loading the platform. That seemed to give me a solid figure. Whether it is right or not is a different question altogether.
Thanks for the links.
07/08/2009 11:00 PM
You're welcome. You provided enough information to narrow the search.
Good luck.
Good Answers: 97
07/07/2009 11:15 PM
See the cookbook "Span tables for joists and rafters" of the American wood council http://www.awc.org/technical/spantables/index.html
Or the online span calculator http://www.awc.org/calculators/span/calc/timbercalcstyle.asp
2" x 8" @ 16" OC with plywood sheathing to max 10' span max load = 100 lbs/sq ft
8.5' span of 2" x 4" @ 16" OC with plywood sheathing = about 35lbs/sq ft.
bwire (1); lyn (2); plancette (2)
