Previous in Forum: Sizing a Common Flare Stack Header   Next in Forum: sand casting risers
Low-Temperature Pipeline Nomeclature
07/07/2009 10:09 AM
Hi,
What does the folowing stand for:
LF2, WPL6 and Class 1 or 2?
Thanks
Dejan
Re: Low Temperature Pipeline Nomeclature
07/07/2009 10:28 AM
hi
The material belongs to low temperature carbon steel
LF2 - Flange (ex A350 LF2 - Fittings)
WPL6 - Elbow (ex A420 WPL6 - Fittings)
Class 1 or 2 - specification in pipe (ex A333 Gr1 , A333 Gr 2)
Regards
Mani
07/07/2009 10:32 AM
thank you very much.
Do you know what W and P and L stand for?
Good Answers: 51
07/07/2009 10:36 AM
LF2 is a grade within the specification SA/A-350; with Class 1 and 2 as subgrades to LF2.
http://www.techstreet.com/cgi-bin/detail?product_id=1533657
WPL6 is a grade within the spec SA/A-420:
http://www.techstreet.com/cgi-bin/detail?product_id=1376616
A little knowledge is a dangerous thing.
07/07/2009 10:42 AM
Hello XMech,
Good to here from you and thanks.
WPL = Welding Pipe Length?
Dejan
Good Answers: 51
07/07/2009 11:29 AM
If you are referring to the 'WPL' of the grade WPL6 of SA-420, I am not sure what it stands for.
Within SA-420, there are other grades as well, for example: WPL3, WPL8, WPL9
And because this spec is for fittings I would guess that "Welding Pipe Length" is meaningless - I would say that it could possibly be a hold over from the old days, and may mean something like "Welded Pipefitting Low-temperature",
In any case, I don't think it is important - it is just nomenclature; for example, what does the "420" stand for in SA/A-420? The answer is nothing - it is just a number.
07/07/2009 11:33 AM
XMech,
Thanks for being logical and concluseve.
I agree with you and like your answer.
Thanks again
Dejan
Register to Reply 6 comments
dejand9 (3); ssmv123 (1); XMech (2)
You might be interested in: Audio Amplifier Chips, Ring Gages, Excimer Lasers
