Previous in Forum: Trailer Wiring   Next in Forum: Mitsubishi Engines - RON92 vs. RON97
Tranny Fluid for a Dodge Neon
07/10/2009 12:17 AM
hi, i got a neon and it's an automatic i can't remember if it takes 4quarts or 5 when i am done flushing it to fill it up completely? please help me!!!!! i would be greatful.
Re: Tranny fluid
07/10/2009 12:24 AM
Put 4 quarts in.
Start car, check fluid level.
Add the 5th quart if the dipstick says it needs it.
Duh!
Re: Tranny Fluid for a Dodge Neon
07/14/2009 12:11 AM
Ask the dealer for the amount of ATF the transmission holds.
But I am curious about your statement "...when i am done flushing it..." How do you plan to flush it? If the transmission can not be drained completely from the pan- because the drain does not remove the fluid in the fluid coupling, you must drain the transmission refill with new fluid and then run the car for several miles before draining and refilling the pan again. In my Honda CR-V I can only drain 3 of the 8 quarts of ATF from the pan. Therefore I drain, refill, run the car and drain again three separate times.I suggest you purchase a Neon shop manual and follow the manufacturer's suggestions.
Dennis Waller
You might be interested in: Helium Neon Lasers, Lasers, Laser Mounts
