Previous in Forum: Bolt Root Area   Next in Forum: Pressure Vessel Nozzle - Set In or Set On Type
Chiller Plant 150 Ton
07/12/2009 10:44 AM
one compressor of two on a carrier 150 ton chiller is not taking any current. Winding has burnt. The chiller is running on almost half load. What are the consequences if i use this on partial load. I have other chillers in fine shape. What amout I need to spend in indian Rs typically for rewinding of the motor of the second compressor. Will it be very costly.
Re: Chiller plant 150 ton
07/13/2009 12:34 AM
It all depends on the application for which chiller is used. If it is used for air conditioning purpose again depends upon the heat load of the building. As it is summer now demand of the plant will be high. If you operate on partial load you get complaint from the end users of the plant. If you use the chiller for process application again you have to check the process requirement. For rewinding the motors you have to contact reliable suppliers and I assume that it will be cheaper in India
