Previous in Forum: Flow Measurment for 3 M X 4 M Rectangle Pipe   Next in Forum: 1 1/8 Inch Steel Cable Weight
8 comments
Load Calculation for a Building
12/07/2006 2:06 AM
Can someone kindly help me get a software to calculate load in building??
I also need to know how to determine the capacity of the load station. there are 30 apartments of approx 20kw usage each. street light spaning about 2km, a swimming pool to be serviced by that station,
Kindly also advice on the breaker and transformer ratings.
regards
archibong
Re: Load Calculation for a Building
12/07/2006 11:10 PM
Get a professional consultant for the job. You would need proper PE certifications for jobs such as these. Not to doubt the capabilities of the forum contributors, you wouldn't want to get burned (not literally) if the implementation doesn't work or worse, accidents due to selection errors.
12/07/2006 11:23 PM
HI,
I am having a similar challange too. I want to construct first floor expnasion of our existing laboratory and to install heat pump for the entire structure cooling .
the hvac expert has asked us to find the mass of the slab and the walls so as to design the system so as to design theheat pump system that would not only provied the air at a comfort conditons but also generate dc currant that would be possibly utilised for electrochemical research reactions
andeshpande
12/08/2006 8:19 AM
You should follow the NEC -National Electrical Code-. Good lock.
12/08/2006 10:26 AM
I work with a mechanical and electrical consulting firm. Block Load v4.13 from Carrier is a popular industry standard tool for doing heating and cooling loads. Quite user friendly. Trane also has software. Phone a supplier, and you may be able to try their demo programs.
Heat loads are very simple calculations. Cooling loads require programs like these because they will factor in sun exposure, etc.
Evan
12/08/2006 10:30 AM
Note: I was referring to heating and cooling loads. If you're referring to electrical only, the aforementioned software isn't applicable.
Evan
12/18/2006 5:33 AM
pls can you get me the reference of the software.
08/07/2009 12:56 PM
u can use carrier E - 20 software for calculating load of any building. any need i can help u
09/29/2009 3:29 PM
first of all, you need to determine the critical load
Register to Reply 8 comments
