Previous in Forum: Sears Building Glass Walkway   Next in Forum: Element 112 Has Been Named
Torch Coloring of Cold Rolled Steel
07/16/2009 7:54 PM
I would appreciate any information on any chemicals or substance that could be applied to cold rolled steel to get different colors other than the basic earth tone golds, blues, purples etc. I have seen examples of metal art that have brilliant rainbows of color that are supposedly done by applying something to the metal to bring out the colors. any help would be appreciated. I have also tried 3 times to register but have not received their confirmation e-mail from cr4. also register on GlobalSpec and am receiving their updates. thanks for your help.
Good Answers: 15
Re: Torch Coloring of Cold Rolled Steel
07/17/2009 7:51 AM
If you're having difficulty registering with CR4, please email cr4admin@globalspec.com with your username.
Sharkles
Good Answers: 243
07/17/2009 10:26 AM
PUSCHERCOLOR , however the colors are a result of Lead sulphide being deposited. Some of the chemicals contain lead...
This works much better on brass, but does work on steel as well.
You might also consider a brass or nickel coating on your steel, which will be a more reactive substrate...
You should also look at electrochemical methods of depositing colors.
milo
07/17/2009 10:39 PM
I know that if CR steel is heated to various temperatures and cooled the oxide formed can/will deposit in varying thicknesses and orientations to give a wide array of colors as the light reflects from the surface. I read about the relationships in a textbook on rust formation, but I dont know if this is the kind of thing you are after.
Good Answers: 58
07/18/2009 6:05 AM
Case coloring is the result of the surface hardening processes used on mild steel. Two of the important processes are bone and charcoal and cyanide. Obtain a text on case hardening and you will find all the information you need. The colors are produced by thin layers of oxide on the surface of the metal. They are fragile and easily scratched. In the gun trade, they are sometimes protected by a thin coat of clear varnish.
Good Answers: 117
07/18/2009 9:58 PM
I have documented this whole process on my armouring blog.... but only the purples and blues, sorry.
http://southtowerarmouringguild.blogspot.com/
Anonymous Poster (1); Milo (1); Sharkles (1); welderman (1); Yusef1 (1)
