Previous in Forum: Phillips Program for Lux Calculation Question   Next in Forum: Can Magnetic Repulsion be Increased?
13 comments
Transformer Design Information Needed
12/08/2006 6:29 AM
I wanted about the information about how to design a transformer
The voltage in our case is 230v and 50 hz.the output we need the secondary voltage 12 volts and current 800milliamphere
So what wiil be the below
1.primary turns and gauge of the primary wire
2.secondary turns and gauge of the secondary wire
User-tagged by 1 user
Re: Transformer Design Information Needed
12/08/2006 8:51 AM
I remember from my school boy experience the you need 9 turns per volt for a one square inch core (excuse non SI units) and pro rata. That was of course with core materiel of 1940 but I don't expect things have changed much
Tables can be found on the internet listing the appropriate wire gauge for the specified currents.
The current in the primary winding will be approximately the voltage ratio times the secondary current i.e 0.8*(12/230)
12/08/2006 9:11 PM
Thats easy things, but you have to know your core's flux density. then youi can get the turns. If you dont know it, yhou will get wrong turn and the transforer will be burned. Syhprom is not quiet right, because he ingore the B value. This tranfermer is cheaper here, I can offer you with regulator. info@ndt.cn
12/09/2006 6:14 AM
I did in fact state that the core materiel was what was available in 1940 when I was a school boy, I doubt that things have changed much over the years
12/09/2006 11:59 PM
thanks for your reply
12/11/2006 9:48 PM
The relationship below might help you in designing a transformer:
Np/Ns=Ep/Es=Is/Ip
where: N - no. of turns
E - Voltage
I - current
12/09/2006 8:06 AM
Hi, sym you are not quite wrong, of cuase not quite right. thoery formula doesnt change any more since Farad times. Maybe there was very little soft magnetic material for transfermer. Today the silicon steel can be from 0.8T to 1.8T. sot that you will have 2.3 time difference turns. Generally we can use it as 1.2T for our counting.Of cuas different area has different turns as well. The formulas would be: V=4.44xSxBxfxexp(-4) where v=voltage V s= area cm^2 B= flux T f= frequency Hz ok you can use this for your transformer making.
12/09/2006 9:24 AM
"9 turns per volt for a one square inch core (excuse non SI units) and pro rata. "
12/09/2006 11:00 AM
Primary winding 230 V 44 mA 2480 turns wire diam 0.15 mm Secondary winding 12 V 800 mA 136 turns wire diam 0.5 mm FeSi Core 20 x 20 mm
12/09/2006 11:25 AM
Is that for 50 or 60 HZ ? the fluz density is about 28% higher than my calculation if it is 50HZ but core materials may have improved over the years.
I am hunting for a small un-potted transformer to take some measurements.
12/09/2006 11:32 AM
Without hunting for the cheapest source I find I can buy a transfomer of that spec for $15, I wonder what it would cost to build just one!
12/09/2006 10:43 PM
50 Hz
12/11/2006 6:24 PM
European Suppliers
11/01/2007 3:39 PM
check Mitchell Electronics for good information on transformers
they have been around for over 50 years....they mfg in NY
www.yesmec.com
Register to Reply 13 comments
Anonymous Poster (2); c3p1124 (1); cnpower (2); Langdom (2); rodney (1); syhprum (5)
