Previous in Forum: Scaffolding Calculation   Next in Forum: Compaction
10 comments
Concrete Sink: Molds and Waterproof Materials Needed
07/19/2009 9:50 PM
I am a stonemason. I talked myself and the homeowner into making a concrete sink directly in a rock wall. Originally I was just going to make a space and drop the bought metal or plastic or ceramic sink into it. I was not really serious, just a quirky suggestion but now they are gung ho! I have a waterproof material called antihydro that you mix into the cement (calcium cloride solution, I think) and I have zipex as a surface treatment. Perhaps there are food issues with both of them. I was not concidering zipex. The biggest concern is if micro cracks devellop as the wall hardens. (The sink will be made of a completely different strength mix so I think it is quite possible). (Could I put a lime mortar mix as a buffer between the 2 types?) It will be beside a gas barbecue that will also be built into the wall. They live beside the sea so perhaps crabs and lobsters will end up there before they get eaten. How will seawater affect calcium cloride? I know it can be done but even the finishing of the surface is problematical. If I make a mold, I have to wait the exact time, then remove it and trowel the surface, incl the curves. It could be a nightmarish project! Your thoughts on problems so that it goes without a hitch? Thank you in advance. Brian
Re: Concrete handmade sink sunk into wall, Molds and waterproof materials needed?
07/20/2009 8:50 AM
Sounds like one of those 'simple' projects which you'll live to regret...or maybe you'll get eaten by an angry Lobster.
Sorry I have no good ideas on the subject...
Good luck
Good Answers: 16
07/20/2009 9:19 AM
Try 'Ferro-cement', using a wire armature starting with a mesh of #9 wire over a #3 re-bar frame, build up with hardware cloth and chicken wire. Use tie wire to compress the thicknesses to about 1/2" - 3/4" max. A fairly stiff sand mix, or prepackaged floor leveling mix is pressed in from both sides and polished with a spoon or similar tool. Keep it damp for as long as you can (at least a week or more). Installation will be aided by incorporating tabs or struts into the wire work.
Ferro-cement has been used for owner built sailing vessels, and is still used for barges and other watertight vessels. There is probably a wealth if info if you google it. I built a hot tub with it, and no further treatment was necessary to keep it waterproof. It polishes beautifully, and you can add some cement dye if you like.
De gustibus non est dispudandum.
07/20/2009 10:31 PM
Thank you. Anyway, the guy talked himself out of it and bought a stainless steel sink today. Thank God! No more joking suggestions. I can just drop it in anywhere in the wall. Whenever work slows down, I want to make a sunken water tank/pond in my back yard so the fero cement tip will come in useful. I am scared to use rebar in a pond. I have seen rusted rebar split concrete. I like the idea of hardware cloth though. It can be plastic. I have broken concrete that had plastic garden fence mesh in it and it was very very difficult to break. Anyway, I am still interested in the sink tech. I occasionally do garden ponds so any extra technical info is useful. Brian
07/21/2009 2:52 AM
Surely if you mount the sink in the WALL the water will just run out.
I know you guys do things different on that side of the pond, but can I suggest you mount in horizontally?
Or have you installed a KrisDelTM localized gravity modification unit (LGMU) behind the sink? That would be handy for washing up...or would that now be washing across?
Or maybe you can can just watch the sink like a big wall mounted flat screen TV
Good Answers: 97
07/21/2009 7:59 PM
You will find this very interesting...
Re: Concrete Sink: Molds and Waterproof Materials Needed
07/21/2009 2:31 AM
Check out "Fine Homebuilding", there is an article on concrete countertops and sinks,(pay of course), but someone may have the magazine. There is also a book available for pouring concrete countertops. Rusty rebar is no problem, you can use hot dipped galvanized, or maybe try the poly shorts mixed in the concrete.
Good Answers: 16
07/21/2009 8:30 AM
Hi vtbgiraud,
Good suggestions, but; "try the poly shorts mixed in the concrete." ?
You mean the ones with the hula girls printed on them? Or is that the concrete block coating with the fiberglass mixed in. It goes under various trade names like BlockBond, Dura..... whatever. Very good for a surface coating about 1/8" thick, but won't force through a wire armature.
I suspect the rusted re-bar had already started to rust before pouring with an inferior grade of concrete. Common with amateurs and "professionals" skimming/skimping on materials. Zinc chromate paint (nasty slime green) is used on all re-rod for bridge work nowadays. BTW: Iron filings can be added to concrete to increase resistance to hydraulic pressure. The rust fills the microscopic cavities.
Happy mud pies.
Good Answers: 37
07/21/2009 8:25 AM
"This Old House" (TV show) did an episode where the homeowner went to a shop where they built her a one-piece concrete countertop and sink (built-in drainboards & all) during the show. They spelled out the mix in considerable detail, and the procedure was shown in sufficient detail that almost any handy person with access to the tools & equipment could replicate - should be a snap for a stonemason. By chance, that episode was re-run locally (Madison, WI channel 21) just yesterday evening. This seems to be the TOH Magazine variant of the story: http://www.thisoldhouse.com/toh/photos/0,,20050150,00.html
" Ignorance and arrogance have more in common than their last four letters. "
07/21/2009 9:32 AM
check these guys out...........i think there may be other competitors.....
http://www.concretenetwork.com/concrete/countertops/
07/22/2009 7:42 AM
How would a nice layer of epoxy paint applied over the finished (and properly cured) product work? It's durable, and I think it's waterproof as well. Your choice of colors.
Cheeries !
Register to Reply 10 comments
bwire (1); gaiatechnician (1); Happy Fish (1); reefdiver (1); Ron (1); Tippycanoe (2); user-deleted-1105 (2); vtbgiraud (1)
