Previous in Forum: Thermocouples   Next in Forum: M62P PLC
Thermocouple
07/21/2009 10:32 AM
can anboby pls tell me how to measure thermocouple with multimeter,while i was selecting temperature display on the multimeter, my input was 150c and i got 150 on the display but when i checked with reference to the temperature chart (mv) mv volt started showing less, chart and mutimeter is not matching
Re: Thermocouple
07/21/2009 10:44 AM
If your multimeter is designed to display temperature when connected to a thermocouple, it will incorporate circuitry to perform cold junction compensation (click to read about it in wikipedia).
Measuring the thermocouple voltage with a multimeter and using a lookup table to find the temperature will not give an accurate result.
Re: Thermocouple
07/22/2009 12:08 AM
Thank you john
Re: Thermocouple
07/22/2009 12:24 AM
Depending on the CJ temperature of the meter, you may be introducing errors by using a meter in temp mode.
Make sure the meter CJ temp has equalised with the ambient temp before taking a reading.
The most accurate method is to only measure mV, and measure the CJ temp accurately (hi resolution laboratory glass thermometer, or RTD in a CJ box), then use your tables.
Re: Thermocouple
07/23/2009 12:35 AM
You check millivolts from Thermocouple and than check on table where is temperature against millivolts
This is good place where technical people share their knowledge
Re: Thermocouple
07/23/2009 12:42 AM
if both mv against chart and temperature displaying on multimeter r same than thermocouple giving prob. if differ in reading on multimeter than change multimeter, by ranjha
Reply Score 2 for Off Topic
Anonymous Poster (1); JohnDG (1); muzza (1); ranjha (2)
