Previous in Forum: Non-Linear   Next in Forum: Designing Springs for Relays
Scraper Launcher - Damaged Door
07/22/2009 7:41 AM
Greeting to all,
I would like your help to solve the problem of the closure door of the scraper Launcher. The closure door is started to leak because of the corrosion and damage in the threads of the closure door. Is there any solution to solve this problem (cheap solution) or I need to change the closure door by new one (Cost solution). How I can avoid such this problem next time.
The scraper launcher is used for the disposal water line, with high pressure around 1600 PSI.
Re: Scraper Launcher - Damaged Door
07/22/2009 4:29 PM
Does the launcher "launch" the scraper in a pipeline?
07/25/2009 9:03 AM
yes, it does
it launch the scraper through luncher to the pipe line
07/29/2009 5:33 AM
Is there any comments or Solution for the subject topic
I have same problem
Your help is highly appreciated
08/31/2009 2:11 AM
Yes, it does
Register to Reply 4 comments
You might be interested in: Door Operators, Door Stays and Lid Stays
