Previous in Forum: ELCBs vs. RCCBs   Next in Forum: What Is This Electrical Device?
Pushbutton Switch
07/22/2009 7:43 AM
CAN ANY FRIEND TOLD ME IF I HAVE TWO NO PUSH BUTTEN THEN HOW IT USED AS STOP AND START SWITCH .
Re: NO PUSH BUTTEN
07/22/2009 8:12 AM
By connection to the two coils of a latching relay (assuming that NO means "normally open". Your question would have been a lot clearer if you had not used upper case throughout your post. Upper case is also considered SHOUTING when used in posts - please avoid it).
Re: NO PUSH BUTTEN
07/22/2009 9:59 AM
The generally accepted practice for a motor starter is to use a NC button and a NO button. These are used in combination with a latching relay; or on a motor starter, there is a auxillary mounted NO holding contact. This combination is often called a start-stop station. The NC button always precedes the NO button in the circuit.
Re: NO PUSH BUTTEN
07/22/2009 10:19 AM
I couldn't agree more.
I was, however, answering the OP's question.
Re: NO PUSH BUTTEN
07/22/2009 11:46 AM
Good answer electricmel.
Bad answer JohnDG!
Good Answers: 804
Re: NO PUSH BUTTEN
07/22/2009 1:05 PM
I disagree, in both cases.
JohnDG was, as he said, responding to the exact question the OP posed, without judgment on it. If I were stranded on a desert island and posed with a problem of only having 2 push buttons (note the spelling atulsaxena ...) with only NO contacts on them, this is the way to solve it (assuming someone had also left me a atching relay of course). It may seem overly complex and not a good idea, but it is the correct specific answer. Technically, if nobody left me with that latching relay, there is NO WAY to affect a Start-Stop scenario with only 2 x NO contacts. So given that, JohnDGs answer is really the only possible correct scenario, even if it does make an additional device necessary.
TECHNICALLY, electricmel made an error in his response, along with a generalization that is not true. "The generally accepted practice for a motor starter is to use a NC button and a NO button. These are used in combination with a latching relay..."
  1. You would NOT use a NO and NC contact along with a latching relay. The latching relay needs the unlatch coil to be energized to release the relay. How would you do that with a NC contact? A seal-in contact on a standard relay does NOT make it a latching relay, becase if power fails, it will not return to the latched state, i.e. 3-wire control. The statement about using the aux. contact of the motor starter is correct in a 3-wire control scenario, the error was just in applying that concept to a latching relay (see below).
  2. "Generally accepted practice" is a little too general. While 3-wire control is a very good idea because it provdes for under voltage dropout and manual resetting, 2-wire control is perfectly acceptable and used almost as much, especially in automated applications. Using a latching relay is exactly how you would do it in the days before PLCs.
I know I'm just being a nit picker here, so flame away if you must...
Re: NO PUSH BUTTEN
07/22/2009 3:40 PM
GA, JRaef. When I read "latching relay" in electricmel's post, my brain replaced it with "self-latching relay", i.e. wired with power supplied to the coil via one set of NO relay contacts and the NC "STOP" button, thus:
... my bad!
Re: NO PUSH BUTTEN
07/22/2009 3:42 PM
"Bad answer JohnDG!"
On what grounds? Register, and justify your comment, if you have anything useful to say.
Register to Reply 7 comments
Anonymous Poster (1); electricmel (1); JohnDG (4); JRaef (1)
You might be interested in: Switch Mode Transformers, Emergency Stop Switches
