Previous in Forum: Leakge Through My Kitchen Slab   Next in Forum: Traveling at Light Speed
33 comments
Is This Brick Wall Safe?
07/23/2009 4:34 AM
Hi,
I have a question regarding brick or masonry design. There is this half-brick wall, measuring 2.8m long x 2.2m high and 115mm thick (plus plaster). This wall is seated directly on a concrete slab without any anchorage. It is also not restrained in any direction as it is not connected to any column, stiffener or beam. Some wash basins are supposed to be installed onto the wall.
My question is: Is this wall safe? Is there any formula, building code or engineering literature that show that a brickwall erected without any restraint is structurally unsafe, regardless whether you load it (eg by installing wash basins) or just leave it simply free standing without any other load on it?
Many thanks in advance.
Pathfinder Tags: brick MASONRY structural design
Good Answers: 143
Re: Is This Brick Wall Safe?
07/23/2009 7:49 AM
n my opinion, which you should treat as an opinion only, it is not safe. Note that I am not a structural engineer nor a civil engineer. For at least several centuries, builders have used either pillars or serpentine or thickness for such walls. In any event, 2.2 m is quite high for any construction material without support against lateral force. Wind, earthquake, or an accidental blow could topple it, again in my opinion.
So, you need to consult your local building code folks. They will have specific guidelines or will require a qualified engineer to review this.
07/23/2009 1:34 PM
I would think a good shoulder charge would knock it down...
Ref, it was a fair challenge, shoulder to shoulder...he dived...it was never a penalty.
07/23/2009 1:59 PM
This is all I have to say (contribute):
http://news.therecord.com/news/More%20News/article/554627
07/24/2009 2:24 AM
Please Check a few things -
1) Is a sill been casted at sill level
2) Is the wall being supported by beam on top
3) Is the wall been restrained on sides
If not then it is totally unsafe to keep the wall as it is going to fall even with a push or bang. I would suggest to either dismantle and reconstruct the wall restraining it on all the 3 sides with sill at sill level (i.e. 1meter). Secondly for the sink part you can construct pillars of reqd size to sustain the same.
07/24/2009 3:03 AM
Interesting that you should ask that he check things...
The post is most peculiar and slightly enigmatic.
It categorically states that various reinforcements/supports/etc don't exist. But if one was knowledgeable enough to make those statements, then surely one would be knowledgeable enough to realise it wasn't safe...?
Spooky eh?
United States - Member - Technical Fields - Education - Hobbies - Hunting - Popular Science - Weaponology -
07/24/2009 2:40 PM
Perhaps he was looking at plans? or maybe he was a cat...I know my cats seem to have mind reading and psychic abilities.
David A Goodman
Good Answers: 68
07/24/2009 3:56 AM
Hello ricqoh,
Sorry if the name is wrong. I could not see if it was a 'g' 'q'.
Surrey Building Control
Guidance Note - Number 22
Garden Walls etc
Garden walls etc are not controlled by the Building Regulations. Building Control however does have powers to remove or make safe garden walls etc if they are considered to be dangerous.
Please consider the following:
Garden and boundary walls should be inspected from time to time to see if any repairs are necessary, or whether a wall needs rebuilding. Such walls are amongst the most common forms of masonry to suffer collapse, and they are unfortunately one of the commonest causes of death by falling masonry.
Besides the general deterioration and ageing of a wall over the years, walls may be affected by:
• An increase in wind load or driving rain if a nearby wall is taken down.
• Felling of nearby mature trees or planting of new trees close to the wall.
• Changes leading to greater risk of damage from traffic.
• Alterations, such as additions to the wall or removal of parts of the wall e.g. a new gateway.
Things to check:
• Is the surface of the brickwork crumbling away?
If restricted to a few bricks this may not be serious but walls can be weakened by general crumbling across either face.
• Is the mortar pointing in good condition?
If the hard surface layer can be picked out from the joint, or if the mortar can easily be scraped out with, say, a door key, then this is a good indication that the wall may need repointing.
• Is there a tree near the wall.
As trees mature, there is a risk of the wall being damaged by the roots, and from wind-blown branches. Damaged sections may have to be re-built, perhaps with bridges incorporated to carry the wall over the roots. Removal of large trees can also lead to problems because the soil accumulates more moisture and expands.
• Is the wall upright?
Walls lean for a variety of causes, due for example to failure below ground caused by tree roots, a cracked drain, frost damage to the foundations or inadequate foundations. If your wall leans to an extent that could present a danger e.g. more than 30mm (half brick wall), 70mm (single brick wall) or 100mm (brick and a half wall) it is recommended that expert advice is sought. This may involve checking of the wall foundations.
• Is the wall thick enough for its height?
The table below gives guidance on how high walls should be relative to their thickness. Seek expert advice if your wall exceeds the recommended height, or in circumstances whereby this guidance is inapplicable e.g. walls incorporating piers, or walls supporting heavy gates or retaining soil.
Thickness Recommended Max. height
½ Brick (100mm) 525mm 1 Brick (215mm) 1450mm
1½ Brick (325mm) 2400mm
100mm Block 450mm
200mm Block 1050mm
300mm Block 2000mm
• Some climbing plants, like ivy, can damage walls of growth is unchecked. Consider cutting them back and supporting re-growth clear of the wall.
• Is the top of the wall firmly attached?
Brick cappings or concrete copings may be loose or there may be horizontal cracks (frost damage) in the brickwork a few courses down. Loose or damaged masonry near the top of the wall will need to be rebuilt and should include a damp proof course.
• Has the wall been damaged by traffic?
Minor scratch marks or scoring of the surface may obscure more significant cracks. Piers at vehicular entrances may have been dislodged by impact and be unsafe; in such cases they should be rebuilt.
• Are there any cracks in the wall?
Hairline cracks (0-2mm across) are common in walls and may not indicate serious problems. For wider cracks seek expert advice; some may indicate a need for partial or complete rebuilding. Seek advice on any horizontal cracks which pass right through a wall or any cracks close to piers or gates. Repointing of cracks can lead to problems. Do not repoint without establishing the cause of the cracking.
Planning Permission
You will need to apply for planning permission if you wish to erect or add to a fence, wall or gate and:
• It would be over 1 metre high and next to a highway used by vehicles (or the footpath of such a highway); or over 2 metres high elsewhere; or
• Your right to put up or alter fences, walls and gates is removed by an article 4 direction (development rights) or a planning condition; or • Your house is a listed building or in the curtilage of a listed building. Normally you will not need to apply for planning permission to take down a fence, wall or gate, or to alter or improve an existing fence, wall or gate (no matter how high) if you don't increase its height. However if your building is listed or in a conservation area you might need listed building or conservation area consent to take down a fence, wall or gate.
Note:
Under the Party Wall Act 1996
you are obliged to consult with neighbours where your garden wall affects the boundary.
Please note that these guidance notes are for advice only and may not cover all situations. It is your responsibility to ensure that they are appropriate for use in your particular circumstance.
Can you give more details about this wall please.
It seems unlikely that a wall of single brick would be built to this height, they may need planning permission. There may be anchors you cannot see at the base. However, if there is anchors, they are likely holding the first couple of rows only. It may have been thought that the 'plaster', (which is more likely to be 'render' if it outside) would strengthen it but render can itself 'blow-of' and be a danger.
I was in building for several years and have seen double brick with pillars, but not single brick this high.
I have to ask you why do you ask if it is safe? Is it on a property you have bought or rent. Near your boundary wall or fence where it could be blown over. Do kids play on it?
Even if it is not on your property you can phone your local Council and asked if they could check it. They will come and use up to date knowledge and reg's' and check it for its safety and can order it to be knocked down if it is not safe. It seems to me this wall could be pushed over, even if it is in an open location, it could still fall on the people who are trying to push it?
I hope this is of use. Keep in touch.
07/29/2009 7:54 PM
Thanks Babybear.
I just got an extract from the BS 5628: CP for design and use of masonry, which states a freestanding wall should not exceed 12t in height, where t is the effective thickness. Think this should answer my initial question.
Thanks again to you and all the other responders (though some may be more constructive than others)
Good Answers: 68
07/29/2009 8:39 PM
Hello ricgoh,
I just got an extract from the BS 5628: CP for design and use of masonry, which states a freestanding wall should not exceed 12t in height, where >>> t <<<is the effective thickness............
Thanks again to you and all the other responders (though some may be more constructive than others.............
What is the word which is 'missing' where only the 't' was typed, between the arrows?
Perhaps "constructive" is the wrong word to use under the circumstances?.... ;=)
07/30/2009 2:00 AM
>>>t<<< the t refers back to the 12t in "should not exceed 12t in height"
In other words if a wall is 4" thick it should not be more than 4' high:
12*(4/12)
Good Answers: 68
07/30/2009 2:11 AM
Hello Randall,
In other words if a wall is 4" thick it should not be more than 4' high: 12*(4/12
I have never heard of this before. But does that mean that a 6" thick wall can be no higher than 6'?
07/30/2009 3:02 AM
Hi bb,
For a freestanding wall of 4" thickness, 6' sounds overly high to me. Still, following from ricgoh, you can read more about the 12t aspect here (about half way down the link, Part 1 - slenderness limits). 12t can't be taken as a single rule that applies to each and every wall - depends on length, wind loading, ground pressure, and a whole bunch of other stuff. If I lived in some places, I'd be checking The Subsidence Engineers Handbook - darned coal mines ! If my neighbour built a 6' wall using toothpaste for mortar I wouldn't be happy (though this being England, we'd spend ages arguing about who owned the boundary )!
Good Answers: 68
07/30/2009 3:35 PM
Hi Kris,
How are you?
I have over 50 emails, when the whole of last week I got 20! I will be here for hours sorting this out so, have saved your notification which links to your post. I can come back to these types of posts and the long ones later.
Thanks for the site link you sent.
Know what you mean about the arguing about the boundary thing!
Take care...........
07/31/2009 2:11 AM
Hi bb,
That's all cool
Good Answers: 68
07/31/2009 1:45 PM
Hi Kris,
Cheers my friend. I still have about 10 to go! Was it my bright idea to post to CR4? Talk about busy!
07/30/2009 5:55 AM
I don't know anything about this subject I was just quoting back and interpreting the "rule of thumb".
07/30/2009 6:20 AM
And good for you ! It'd be an awful quiet place if we all sat back waiting for somebody who knew everything. Input from all quarters helps to raise issues that might not otherwise be covered. That's why CR4 is better than all the dry technical sites out there - we have discussion and interpretation.
This reminds me of a recent quote I read (Tony Benn of all people); 'With so many people learning and discovering new things all the time, I go to bed knowing comparatively less than when I woke up'. We are all learning to some degree or other.
Bravo on your candour. I just take it as said that people will guess I know diddly-squat about anything I comment upon ! A sensible reader will check and verify any information they get, no matter who it's from or on what topic.
Good Answers: 68
07/30/2009 6:00 PM
Hi Randall,
No problem my friend. The stuff you send in your post 't' etc, is going to lead to me (and others) learning some new stuff? It is a term I have not heard before, that's all.
Please continue sending your interesting post OK?
07/24/2009 4:14 AM
"Is the wall safe" !!
It's not the wall I'm worried about, it's anyone standing nearby when it falls on them.
07/24/2009 4:38 AM
It is difficult to imagine the reason for such a wall in the first place and I am surprised the wall has not fallen over already.
If the wash basins are heavy duty floor-standing then they might give support to the wall.
But if hung on the wall, on the wall dioes not fall over while you are cutting and drilling it for pipes and fixings, then they might later pull it over - onto the person(s) standing there - especially if someone puts additional weight on the basins (washing their feet).
In any case will it matter if it falls over - just a petty nuisance - or a serious claim for damages - which if arising you will be defenceless because you have put on record that you suspect the wall could be unsafe.
Good luck
07/24/2009 8:57 AM
No from what you have give it is very unsafe. Are there kids in the area as they will play and push on the wall if they think it moves
Good Answers: 56
07/24/2009 10:02 AM
RICQOH WROTE: "It is also not restrained in any direction. . . . "
How do you know this?
It is a common practice for wood framed buildings to have non load bearing brickwork as a decorative outer layer. Typically the wood face is built with metal strips secured in place with fasteners. When the masons lay down the brickwork, those strips are bent out at an angle, and mortared onto the top face of each row of bricks purposefully to hold the masonry securely to the building.
Because these strips are cut just short of the brick's width, their presence is hidden from sight, especially after the brickwork is pointed with mortar. This standard method of treatment could be there without your knowledge.
To be certain, you need to get a metal detector and scan the vertical wall over it's entire surface, marking each alarmed spot with a non-permanent, visible marker. If the brickwork is secured, and I suspect it is, a regular pattern of metal attachments will become readily apparent.
By the way, it MUST be a metal detector. stud detectors designed for "looking" through wall board are not as sensitive.
Wash basins, with their own pedestals, are standard fare. Given the alternative, there really is no need to attach any sink to any wall, regardless of its construction. It might however, prove advisable to anchor the sink pedestals to the cement ground slab you spoke of, which makes the entire issue moot.
Please let us know
L.J.
"Both the revolutionary and the creative individual are perpetual juveniles. The revolutionary does not grow up because he cannot grow, while the creative individual cannot grow up because he keeps growing." Eric Hoffer
Location: united states, california san francisco bay area native
07/24/2009 12:30 PM
great a ,
the house i grew up in, was built in 1906. the garden wall was brick on a concrete footing , rebar had been placed thru holes in the brick, giving it a vertical presence. from maybe the 3rd tier down, anyway,...to my joy when tasked to remove it , to widen the drive way...
i did just make the assumption that the lady , our neighbor , who had lived there since her house , then our house were the 1st two on the block., never spoke of that wall being fixed. she had gas outlets on her walls for light fixtures. 64 ~ 68 , no tv, listened to the radio, and read. power was installed in `28. some might remember the two button push type , spst , switch. and a complete recall of the neighborhood's growth. made the best fudge, after every project, uhmm..cast iron stove, oven , the " ice box " was still installed . the refridge was free standing, by the (1 ) plug in the kitchen.
ah,
wonder if the times of the 40's & 50's in the US : could this be the event horizon for many 3rd world nations ?
still, great answer, make the issue mute:..
give the hardest job to the laziest person & they'll find the easiest way to do it
07/25/2009 1:17 AM
Hey all,
Thanks for all your replies and inputs. To answer some of you, the reason I know the wall was not restrained in any direction is because it had collapsed and I found no anhchors or bonding strips anywhere in its structure that connected it to any permanent structure. It was not connected to any column or stiffener at its sides or beams at its top. It was simply seated on the floor slab, bonded by cement mortar.
I am not a professional engineer, but it is my opinion that this wall, even if it was not loaded, was not constructed safely. However, I would like to have concrete supporting evidence that the wall was not constructed safely, hence, I was wondering whether there was any calculation, building code or engineering literature that are relevant.
Thanks again!
07/25/2009 2:25 AM
the reason I know the wall was not restrained in any direction is because it had collapsed.
AAARGGHH.
Well, why were you asking if it is safe, when it self evividently isn't???
I have a similar question that maybe you can help me with.
If I slip with a big fat wood rasp and it makes contact with my thumb will it leave a row of parallell lacerations which will sting like hell?
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
07/25/2009 3:29 AM
No Del - it won't.
That's because cats don't have thumbs, as any fewl noes
Chaos always wins because it's better organised.
Good Answers: 56
07/25/2009 5:29 AM
I just noticed you live in Singapore.
That changes everything!
Building codes? WHAT building codes?!
L.J.
Popular Science - Biology - life lover Hobbies - Musician - music lover Safety - Hazmat - better safe than sorry United Arab Emirates - Member - desert trek Technical Fields - Procurement - procurement
Good Answers: 58
07/25/2009 8:25 AM
perhaps OP was trying to theoretically confirm the obvious.
Now the darkness only stays the night-time, in the morning it will fade away. -- George Harrison (All Things Must Pass)
07/29/2009 8:53 AM
Speaking from experience ye bowyer cat? Sounds like KrisDel needs to produce a new safety training video...
David A Goodman
Good Answers: 68
07/25/2009 6:04 AM
Hello ricqoh,
I assume you mean part of another bit of a similar wall fell over?
If by all accounts and by the law of the land (if you live in England UK) the wall is too high for its thickness. Lean on it and if it falls over it can stay like that! As you would have proved beyond a doubt it IS unsafe.
07/25/2009 6:28 AM
It's safe now that it has collapsed
07/25/2009 12:06 PM
wow,
let me see , ) 2 possible scenario's:
in the 44 hours between the op and the annoucenment : the wall collapsed.
) the wall had collapsed prior to your initial question.
please be so kind as to verify our curiosity ?
Good Answers: 88
07/25/2009 12:07 PM
My 7-year-old daughter poses similar questions on occasion. For instance, "Who is buried in Washington's tomb?" Yours takes this one step farther:
Q: "Who is buried in Washington's tomb?"
A: "Washington, of course!"
Q: "Yes, but who is buried in Washington's tomb?"
A: "My 7-year-old daughter poses similar questions ..."
Register to Reply 33 comments
ahuha (2); Anonymous Poster (3); babybear (7); DAG (2); English Rose (1); horace40 (1); Kris (3); langyaw (1); Laughing Jaguar (2); Randall (3); ricgoh (2); TVP45 (1); user-deleted-1105 (3); user-deleted-13 (1); vinayakap (1)
