I forgot my password.
Don't have an account?
what is LCI soft starter and how it works please explain me detail
Check http://cr4.globalspec.com/comment/180653
Couldn't have said it better myself...
Neither could I and it was quicker this way. Great answer.
MEGADRIVE-LCI
Static Frequency Converters for soft starting of synchronous
machines in power plants.
MEGADRIVE-LCI -Proven technology
Benefits:
• More than 30 years of operational
experience
• High efficiency
• High reliability and availability
• Also used for motor and generator
(braking) operation
• Low maintenance requirements
• Standard designs are available for
powers up to 72 MW and voltages
up to 10 kV
Load Commutated Inverter (LCI)
Vast operational experience
During its 30 years of production, the MEGADRIVE-LCI has gained an
undisputed reputation for reliable operation in the harshest environments.
Unmatched reliability for high powers
The MEGADRIVE-LCI is the preferred choice when it comes to reliable
and efficient operation in applications requiring high-power and highvoltage.
Standard designs of the MEGADRIVE-LCI are offered and
range up to 72 MW in size, and engineered designs of 100 MW and
beyond are also available.
In 1997, ABB set a world record by delivering the largest and most
powerful electric variable speed drive to NASA. The MEGADRIVE-LCI
controls the 135'000 hp (101 MW) synchronous motor of a wind tunnel
fan.
Worldwide references
ABB has more than 750 MEGADRIVE-LCI units installed worldwide for
a total combined power of 4300 MW, including applications in power
plants, the oil, gas and chemical industries, in water pumping stations,
marine propulsion systems and in test stands.
ABB pioneered the static starting method for gas turbines and synchronous motors, introducing the first static
starting configuration to the market in 1974. Over the years it has become the standard starting technology for
heavy-duty gas turbines and pumped storage hydro turbines. Gradual improvements of the original design has led
to a system which today represents a state-of-the-art Static Frequency Converter. The ABB system configuration
ensures very high starting reliability and also increases gas turbine availability.
Gas fired turbine power plant
ABB
Static Frequency Converters enable gas turbines to be run up to a speed
above which they are self-sustaining. At this speed, the Gas Turbine can
accelerate independently to its rated speed. Gas turbines often have to be
started and run up quickly at short notice, while avoiding a large starting
load on the public supply system.
MEGADRIVE-LCI -Soft starting capabilities
Starting of motors and generators
Direct on-line starting of large synchronous machines
causes inrush currents of up to six times the nominal
current and imposes large electrical stress on the supply
network, thermal stress on the motor and mechanical
stress on the shaft string.
These problems can be overcome with the use of a
MEGADRIVE-LCI soft starter. Aiming to secure your
investment and keep your assets operating at their highest
levels of efficiency and reliability is made possible with an
ABB Static Frequency Converter.
Gas turbine starters
Gas turbines often have to be started and run up quickly at
short notice. ABB MEGADRIVE-LCI gas turbine starters
use the generator as a motor and run it up to a speed
which is above the ignition speed of the gas turbine. The
gas turbine can then accelerate the generator independently
to its rated speed and synchronize it to the power system.
Start-up with the ABB MEGADRIVE-LCI can be done
within minutes.
Starting a large synchronous machine on-line can have a negative impact on the network and the machine itself.
These problems can be overcome with the MEGADRIVE-LCI soft starter.
Main features
• Soft starting and running up of gas turbine sets
• Fast start-up
• Selectable running-up period (5-10 minutes)
• Starting current limited to rated current or less
• Several machines can be run up one after the other
• Regenerative braking (energy fed back to the power
system)
• Microprocessor-based control system
• Air-cooled
• No restriction on the number of starts or the time
period between them
• No gear box required
• Integrated excitation unit for running-up (optional)
• Change over unit fitted when several frequency converters
and gas turbine sets are installed in a power
station (optional)
Advantages for the user
• No moving parts requiring maintenance
• No overloading of the prime mover or the start-up
converter
• Low investment by using one converter for several
gas turbine sets
• Simplified fault-finding
• Longer lifetime of equipment
Cross section of a gas turbine
MEGADRIVE-LCI -Main components
Thyristors
Thyristor power semiconductors are developed for high powers, highest reliability and low losses. They have low on-state
and switching losses, which results in a converter efficiency of 99%, including the DC reactor.
Rectifier
The rectifier is line commutated and forms a fully controllable DC current source in conjunction with the reactor in the DC
link. A 6 or 12-pulse rectifier configuration is available for minimized harmonic influence of the converter on the supply
system. The MEGADRIVE-LCI meets the most stringent requirements for current and voltage harmonic distortion as
defined by IEEE, IEC and EN standards.
DC link reactor
The DC link reactor smoothes the DC current and limits its rate of change in the event of a fault.
Inverter
Thyristors in the inverter electronically switch the DC current to produce a 3-phase AC system of variable frequency and
voltage for supplying the motor. The motor voltages commutate the inverter phase currents. At very low speeds (0-10% of
rated speed), when the motor voltage is too low to guarantee reliable commutation, an artificial commutation is used. The 6
or 12-pulse inverter configuration is available for minimized influence of the converter on the ripple of the motor torque.
Starting excitation converter (optional)
The excitation converter provides the required generator field current at start-up.
Control
The control adjusts the actual torque or speed of the motor to the reference value. It generates the firing impulses for the
thyristors in the rectifier, the inverter and the excitation converter to maintain the desired current, cos phi and voltage of the
motor.
The MEGADRIVE-LCI uses reliable, well-proven components, which were specifically designed for high-power
and high-voltage applications.
MEGADRIVE-LCI -System reliability
AC 800PEC Control Platform
The control part of the MEGADRIVE-LCI system uses the high-end process control
system AC 800PEC, belonging to the ControlIT product line. The AC 800PEC is a
modular high-speed control system, with modules arranged according to the required
I/O configuration and process. It excels with very high processing speed and is fully
integrated into ABB's ControlIT software environment.
MEGADRIVE-LCI air cooled
In order to protect the equipment from overheating, the ABB MEGADRIVE-LCI
utilizes robust fans for air cooling. The specially designed fans will maintain the
equipment within safe operating temperatures and ensure optimal operation of the
equipment by effectively dissipating heat.
Gas turbines or machines in pumped storage power plants must often be started and run-up quickly at short notice.
The MEGADRIVE-LCI Static Frequency Converter uses the generator as a motor to run it up to a certain speed. For
gas turbines, this is above the ignition speed from where the turbine can accelerate the generator independently up to
rated speed and synchronize it to the power network. For pumped storage power plants, the MEGADRIVE-LCI
accelerates the generator up to rated speed and synchronizes it to the power network as well.
MEGADRIVE-LCI Control Terminal
The MEGADRIVE-LCI Control Terminal is used for monitoring and controlling a
Static Frequency Converter and is located on the system's control door panel. The
Control Terminal is a powerful industrial PC with a user-friendly Human Machine
Interface (HMI) that runs independently from the system's control platform. All
communication is done via Ethernet connections and provides the operator with a
range of selectable screens with an LCD touch screen.
• One MEGADRIVE-LCI converter can start several generators
• Unlimited number of starts
• Fuseless design for high reliability and less spare parts
• User-friendly Control Terminal
4 ABB
MEGADRIVE-LCI -Service, Support & Testing
To verify that the quality standards and customer requirements are fully met, every component is subjected to
thorough testing. ABB also offers unrivalled service and support from the customer's initial inquiry and
throughout the entire life-cycle of the system.
ABB solutions ensure the continued reliable operation and optimal performance of your Static Frequency
Converter by offering a fully comprehensive service plan that will provide you with peace of mind.
Gas turbine
Routine tests
Routine tests and functional tests form an integral part of the
scope of supply of a MEGADRIVE-LCI system. They are
performed in accordance with international standards and ABB
quality assurance procedures (ISO 9001.)
Installation and commissioning
Substantial benefits can be gained from proper installation and commissioning of the equipment. Predictive testing and
inspection, in addition to traditional operational parameter setting, done by ABB's qualified and certified commissioning
engineers, will reduce start-up time and cost while increasing safety and reliability. In addition, ABB customers can be given
practical training by experienced specialists on site. A range of training programs are offered from basic tutorials to
programs tailored to the customer's specific needs.
Technical advice
As originators of AC drives technology in the late 1960's, ABB has
over 35 years of application know-how in all industrial sectors, in
virtually every country. ABB's specialists are located around the world
to offer advice that ensures trouble-free operation of ABB products.
Certified support and spare parts
ABB understands that spare parts availability and support is critical to insure on-going operation. For this reason, ABB's
global logistics network is strategically positioned to provide fast parts and repair service, 24-hours a day, 365 days a year.
Our global organization uses standardized processes, tools and metrics to better serve our customers, allowing them to focus
on their core business.
Life-cycle management
ABB's life-cycle management model provides customers with the maximum profit for their purchased assets by maintaining
high availability, eliminating unplanned repair costs and extending the lifetime of the MEGADRIVE-LCI. Life-cycle
management maximizes the value of the equipment and maintenance investment by providing spare parts and technical
expertise. It also provides efficient product support and maintenance for improved reliability. This will insure a smooth
transition to a new technology at the end of the products life cycle.
At home everywhere
After sales service is an integral part of providing our customers with a reliable and efficient MEGADRIVE-LCI. The ABB
Group of companies operate in more than 100 countries and has a worldwide network of service operations. Wherever you
are, ABB is there for you!!!
24-hour North American service & support line
1-800-665-8222
ABB 6
ABB Inc.
Excitation Systems & Static Frequency Converters
10300 Henri Bourassa West
St-Laurent, QC H4S 1N6
CANADA
Telephone: (514) 332-5350
Fax: (514) 332-0609
Certified Service & Support: 1-800-665-8222
www.abb.com
Blatant advertising like that is the kind of thing that kills a technical forum. Too cowardly to use their name as well.
Where did you copy this extremely long, too long, article from?
