Previous in Forum: Solution for Avoiding Green House Effect.   Next in Forum: Cooling Paint Booths
Propane regulator - timed shut off
12/09/2006 12:39 PM
HI:
I am building a smoker for fish, I would like to be able to start the smoker and leave it for a period of time. I am considering electric or propane. The smoker will be 20 - 45 cubic feet.
I have a woodstove/old refrigerator type of smoker now, want to upgrade, this is time consuming and a day long activity. I commercial fish, always have something to do. Need to free up time.
Is there a propane regulater that has a timer for automtic shut off (ie: after 4 hrs)?
Any suggestions?
Thanks, Bob.
Pathfinder Tags: propane regulater
Good Answers: 120
Re: Propane regulator - timed shut off
12/09/2006 11:23 PM
I have seen modenr gas ranges with that type of oven timer.
You may be able to get the control part and adapt it. They usually require a thermocuple in the flame. If the flame stops, the valve shuts off.
A 12 timer and a solenoid valve would do on a car battery. Make it normally closed and the battery holds it open until the timer shuts the volts off.
That is fail safe.
Per Ardua Ad Astra
12/10/2006 12:46 AM
think about a furnace for parts to adapt. there is a thermostat that can be controlled by a timer. your local heater guy throws away systems when the heat exchanger goes bad. you dont have a problem with carbon monoxide.
12/10/2006 12:57 AM
for electric, my dad uses a hot plate with wood chips. travel trailers have heat systems that might be about the right size for gas.
Good Answers: 75
12/10/2006 2:21 AM
The only concern I have is leaving a gas burner unattended is a potential disaster. You need to monitor the flame to make sure the gas is burnt and not just being vented into the chamber and turning it into a bomb.
I would look at using a boiler or furnace controller as they have everything you need built in. Just make sure that the way you build it is fail safe, i.e. it shuts down in the event of a fault or failure.
12/10/2006 5:21 AM
the refrigeration industry has a electricaly opperated control device called a sortie valve for multiplex comercial refrigeration systems like at grocery stores. It may or may not work.
Anonymous Poster (3); aurizon (1); masu (1)
