Previous in Forum: How to Select a Valve   Next in Forum: Vendor Drawing - Pumps and Compressors
India - Member - Atul Singla Engineering Fields - Piping Design Engineering - Atul Singla- INDIA Engineering Fields - Mechanical Engineering - New Member
Pipe Thickness and ASME 31.3
07/24/2009 9:22 AM
While calculating the thickness as per the ASME 31.3, we get the following conditions:
D/6> Tmin
P/SE < 0.385
Can anybody let me know what is the philosophy behind these conditions??
Atul singla
Re: Pipe Thickness and ASME 31.3
07/25/2009 1:38 AM
The provision you're referring to is for thick wall pipe and says (in words) that if the nominal wall thickness is greater than 1/6 the OD you need to use a modified value for the Y factor and pay particular attention to fatigue, thermal stress and the actual failure criterion.Thick pipe is considered to be pipe for which the thickness is greater than one-sixth the OD (t > D/ 6). The condition relates to all pipe for which t > D/6 not just equal to D/6. The definitions for Table 304.1.1 shows that you use a modified value to determine Y. That's because the variation of stress through the wall of the pipe is different for thicker pipe. if you'll look at the stress relationship for thick wall cylinders you find that the departure from thin wall behavior becomes numerically significant for T > OD/6.
07/27/2009 12:28 PM
So it is all about the Hoop stress.. i understand that with increase in pipe thinckness hoop stress also increases..and hence the conditions change .i.e we need to consider the thermal stress and fatigue too... and hence we go for some other condditions..
Atul singla
07/25/2009 5:39 PM
The prescribed limits are for thin wall (membrane) equation where we considered (with an approximation) the cross-sectional area of the pipe metal as (Π D t), where the actual cross-sectional area must be (Π/4)(Do2 - Di2). Therefore, for thick wall (mean higher pressures) we have to use what we call Lame's equation, and this makes the longitudinal pressure stress equation equal to P Di2 (Do2 - Di2).
● In reality, the hoop pressure stress varies thru the thickness of the pipe. This stress variation is defined by Lame's equations which apply equally for thin and thick walled tubes as per European preference.
● By using thin wall equation as per American codes, the hoop stress is considered the same thru the thickness of pipe wall and equal to PD/2t.
While by using thick wall equation, the hoop stress inside the pipe wall is equal to P(Do2+Di2)/(Do2 - Di2), while the hoop stress outside the pipe wall is 2P Di2/(Do2 - Di2), which is preferred to be used as per European codes to be used for both thin or thick wall. For thick wall, the Americans have another equations differ from that equations used for thin wall.
Conclusion. For any calculation per ASME B31.3, you have to apply the rules of that code that satisfy the code conditions of applying the equations of membrane stress:
1. Check that D/6 > tmin (can be checked after calculating tmin)
2. Check that P/SE < 0.385
If the above conditions were not satisfied, you have to use -as per ASME code- the equations for thick wall (high pressure).
07/27/2009 12:30 PM
It was really a nice reply..
May i know about the y factor which changes with increase in thickness.
What is this factor all about and how is it affecting the thickness by doing some back calculations...
Atul singla
07/27/2009 2:03 PM
The values of Coefficient Y depends on type of material, temperature and thickness limits. And as per ASME B31.3:
● For t < D/6: Y can be located from Table 304.1.1, and
● For t ≥ D/6 : Y = (d + 2c)/(D+d+2c),
Table 304.1.1
Temperature, °C (°F)
.≤482510538566593≥ 621
.(900 & Lower)(950)(1000)(1050)(1100)(1150 & up)
Materials
Ferritic steels0.40.50.70.70.70.7
Austenitic steels0.40.40.40.40.50.7
Other ductile metals0.40.40.40.40.40.4
Cast iron0.0……………
Where,
c = sum of the mechanical allowances (thread or groove depth) plus corrosion and erosion allowances.
D = outside diameter of pipe as listed in tables of standards or specifications or as measured
d = inside diameter of pipe. For pressure design calculation, the inside diameter of the pipe is the maximum value allowable under the purchase specification
08/07/2009 12:42 AM
yes that is ok..these tables are given in 31.3..but what does it stand for...no information is given about this factor...except for the table and formula...
I just wanted to know what it is and how it is imparting its effect...
Atul singla
07/27/2009 2:12 PM
Atul singla
Register to Reply 7 comments
Abdel Halim Galala (2); Anonymous Poster (1); singlaatul (4)
