Previous in Forum: High accurate liquid level measurement   Next in Forum: Monitoring Carbon Black in Silos
Titanium welding
12/10/2006 3:23 AM
I want to know,In Titanium sheet SB265Gr2 butt joint weld lot of porosity defect came. How did we improve weld defects. Please give solution.
Thanking you
PORCHEZHIAN
Re: Titanium welding
12/11/2006 1:14 AM
Purchase the automatic butt welding machine from
Parker Hannifin
Huntsville, Alabama
Corn Stoves
12/11/2006 4:13 AM
1st Plz specify what is the thickness of te sheet and whst type of welding technique you r using.
in EBW, the join is not butt tpe it is sheet to sheet metal joining.
Regards
Mobeen
12/11/2006 9:31 AM
Porosity can be caused by many things but nearly always it is cause by oxygen contamination of the the weld molten puddle. Usually is weld joint cleanliness or insufficiant shielding gas. Anything that can burn and create smoke can push the shielding gas away from the weld puddle area and let oxygen contaminate it. Be sure to clean everything very well and do not touch the weld area before welding is started. Any kind of oil can cause porosity even oil from your skin. Alot of titanium is welded in chambers purged with argon to eliminate this. Look at what you are doing, would it help to use a argon trailer or back purge to help protect the molten puddle more? Steve
12/12/2006 8:14 AM
First you must have clean plates. Then you need to use a controlled environment, like a sand blasting cabinet with low pressure of argon pumping in it. This will help clean the weld up while welding.
