Previous in Forum: Postponed Packing Gland   Next in Forum: Hydraulic Cylinder Manufacturing
Air Conditioning Term
07/26/2009 11:17 PM
What is a venturi in air conditioning terminology
Re: venturi
07/26/2009 11:20 PM
The Venturi effect is the reduction in fluid pressure that results when a fluid flows through a constricted section of pipe. The fluid velocity must increase through the constriction to satisfy the equation of continuity, while its pressure must decrease due to conservation of energy: the gain in kinetic energy is balanced by a drop in pressure or a pressure gradient force. An equation for the drop in pressure due to the Venturi effect may be derived from a combination of Bernoulli's principle and the equation of continuity.
The limiting case of the Venturi effect is when a fluid reaches the state of choked flow, where the fluid velocity approaches the local speed of sound. In choked flow the mass flow rate will not increase with a further decrease in the downstream pressure environment.
However, mass flow rate for a compressible fluid can increase with increased upstream pressure, which will increase the density of the fluid through the constriction (though the velocity will remain constant). This is the principle of operation of a de Laval nozzle.
Referring to the diagram to the right, using Bernoulli's equation in the special case of incompressible flows (such as the flow of water or other liquid, or low speed flow of gas), the theoretical pressure drop (p1 − p2) at the constriction would be given by:
where is the density of the fluid, v1 is the (slower) fluid velocity where the pipe is wider, v2 is the (faster) fluid velocity where the pipe is narrower (as seen in the figure). This assumes the flowing fluid (or other substance) is not significantly compressible - even though pressure varies, the density is assumed to remain approximately constant.
