Previous in Forum: Maximum Flow in a Piping System   Next in Forum: Wanted: Indian Manufacturers of Flushing Rings
India - Member - Atul Singla Engineering Fields - Piping Design Engineering - Atul Singla- INDIA Engineering Fields - Mechanical Engineering - New Member
Reinforcement Calculations - ASME 31.3
07/27/2009 1:56 PM
While calculating the reinforment requirements..as per the ASME 31.3, while calculating the A4 we need to take into consideration the differnet types of welds..which is a little confusing...
can anybody help me out for calculating the different cases of A4..
calculating area of triangle is ok...but for ring type case..it is really difficult..if anybody could explain it???
Atul singla
Pathfinder Tags: reinforcement calculations
Re: Reinforcement Calculations - ASME 31.3
07/28/2009 12:53 AM
for caluation reinforcement pad or ring joint , refer appendix H of ASME B 31.3 edition 2004 (sample calculation for branch reinforcement).
07/28/2009 9:26 AM
I k now about those examples...what i am asking is about the A4, is there any reference for calculating the same. There are number of cases given for the same in the welding section, which one to choose and when??
Is there any other reference given in the code or some where else?
Atul singla
07/29/2009 1:23 AM
for calculating strength of branch connection :-
a) first you have to calculate the branch strength without pad .
A4 = Area of weld metal at branch
= 2 tc^2 (tc= lesser of 0.75Tb or 6 mm) Tb- Nominal thickness of branch (mm)
if additional reinforcement pad (A2+A3+A4< A1) is required as par example -1
b) calulate branch stength with pad
A4 = Area of Pad+ area of weld at banch + Area of weld metal at pad edge
A4 = Tr(Pad OD -Db)+ 2tc^2+0.5*Tr^2
Tr - Nominal thickness of pad(mm)
Db - Diameter of branch (mm) as given in example 2 and 4 for 90 degree intersection
and example 3 for 45 degree intersection.
in case if above explanation is not sufficient for you , then you send me your mail i.d i will farword refrence calculation for that.
09/13/2010 6:14 AM
Dear Sir, I have gone through ur suggestion but its not clear to me. Can u pls send a detailed example for that.
04/24/2012 10:40 PM
Hi,
Could you please send across a typical calculation sheet for finding the value of A4 ? I'm also finding difficulty in fixing up the pad size as per 31.3
My email is *
thank you !!
*CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
08/13/2014 5:31 AM
in asme b 31.3 its shoe that to find A4 they calculate with minimum leg dimension of fillet weld
08/31/2014 8:20 AM
sir,
can we use different material for branch conection .
for eg 12 INCH A 106 GR B AND 24 INCH A 672 GR C
Register to Reply 7 comments
Anonymous Poster (1); chellsbreeze (1); munneykhan (2); shamnas (2); singlaatul (1)
You might be interested in: Round Belts and O-ring Belts, Check Valves, Gas Valves
