Yair... me agin'. I'm wondering can a smaller generator with an out put (say) 20% higher than the name plate rating on the driven motor be used to start a variable frequency drive.
That is to say... can the drive be gradualy bought up to speed from the lowest frequency setting thus obviating the problem of needing an over sized generator to supply sufficient amps to start the motor.
I had this problem with a chiller box. The 4kva Lister wouldn't start it so I made up a knife switch, started the chiller with the 8kva and then switched them over. Worked fine and the little 4kva was pretty much under optimum load most of the time.
Any thoughts?
