Previous in Forum: ALLOYS STEELS   Next in Forum: Shelf Life and High-Temperature, Short-Duration Pasteurization
Mr Hill
07/31/2009 6:40 AM
How can i build a wet chlorine gas scrubber to neutralize chlorine gas?
Pathfinder Tags: chlorine gas
Good Answers: 101
Re: Mr Hill
07/31/2009 11:26 AM
Use sodium hydroxide or potassium hydroxide as your reagent. Ensure that the pH is as high as possible for maximum efficiency. For gas scrubbers, packed tower or plate tower designs work very well. You will need to know your expected airflow rate, anticipated influent chlorine concentration, maximum allowable effluent chlorine level, air temperature and air pressure. You can get detailed information on designing a scrubber at the following website: http://yosemite.epa.gov/oaqps/eogtrain.nsf/DisplayView/SI_412C_0-5?OpenDocument
Re: Mr Hill
08/03/2009 7:21 AM
Thanks for your input it was most helpful Mr.Hill
Register to Reply 2 comments
