Previous in Forum: Tranformer Ratings   Next in Forum: Calculating Illumination Level
Current Injection to Test MCCBs
07/31/2009 10:04 PM
Hi members,
Need to know range of driving voltages for testing trip characteristics of MCCBs and
motor protection circuit breakers?
sp rajah
New Zealand - Member - Kiwi
Good Answers: 29
Re: Current Injection to Test MCCBs
08/02/2009 4:35 PM
If you are just checking trip current, the voltage can be very low.
I often have to test MCBs for trip current, and the test set that I use consists of an old-fashioned arc welder transformer which is fed on the primary side from a 230V supply via a variac. The MCB is connected as a short-circuit load on the secondary side, and the current is measured with a clamp meter. With this setup I can test at up to 120A for short bursts, and up to ~100A sustained.
To test MCCBs you could build up a similar test set, but you will need more current, at least 2.5 times the rated current of the largest MCCB that you wish to test.
paulusgnome
