Previous in Forum: Shelf Life and High-Temperature, Short-Duration Pasteurization   Next in Forum: Detecting Cobalt 60 in SS 316L
Equivalent Material to SA 203 E
08/02/2009 12:47 AM
Dear All Members,
I need some advice regarding matter below:
I have vessel datasheet with design temperature is 120 degree C(max) and -90 degree C(min) SA 203 E. Unfortunately this material are not common used, so what is equivalent material able to stand with these both temperature. Stainless cannot used , Could anyone advice me regarding this matter.
Kindly, prompt respond are appreciated.
Thank you.
Good Answers: 68
Re: Equivalent Material to SA 203 E
08/03/2009 12:12 AM
Hello FAIZ,
The metal you reference, is it 'Sa203e / D High-strength Pressure Vessel Steel'
You can go to this site below are check it.
http://www.traderscity.com/board/products-1/offers-to-sell-and-export-1/sa203e-d-high-strength-pressure-vessel-steel-plate-80731/
You mention the temperature band it needs to work in. Do the temperatures refer to the 'liquid' the pressure vessel will hold?
More details would help please?
I assume you want the 'raw' sheet is that right? Or do you want a vessel from other material?
What do you want to use this for. What are the product/s inside and where will it be placed?
Hobbies - DIY Welding - pipewelder
08/03/2009 11:09 AM
I call this plate "colder service" vessel plate and I think the nickle is added for that reason. I looked it up in sec II but I didn't have time to research an alternative. If I get more time I will look further into it and get back.
pipewelder
Good Answers: 68
08/03/2009 10:28 PM
Hello pipewelder,
I thank you for your reply post.
If you can tell me you cannot use the Steel you referenced, I will look for a replacement. But I need to know whether you want a pressure vessel or raw steel.
I would say if you wanted an alternative, a raw steel plate would be the most likely way to get the spec you want?
08/03/2009 11:17 PM
Hai Babybear,
Our company are involved with preesure vessel fabricator(U,U2 & R-stamp). So i only need a raw material for fabrication. What material is equivalent properties with SA 203-E. i want to propose to my client.
Thank you.
Good Answers: 68
08/04/2009 1:39 AM
Hello FAIZ,
Thanks for the reply. Check out these please:
http://www.raajratnaelectrodes.com/selectionguidea.htm
This is a cryogenic steel site:
http://www.industeel.info/products/cryogenic.asp
http://www.klsteel.com/sdp/229183/4/pd-1029274/3584499-516042/Pressure_Vessel_Steel_Plate.html
http://www.regencysteelasia.com/pdf/pdf13.pdf
Look near the bottom of this page for vessel steel of a similar spec
Can you confirm you want plate. Or do you want plate and pipe? Are you able to get the pipe from the same dealer as the plate?
Please let me know if this are of use.
babybear (3); FAIZOL82 (1); pipewelder (1)
