Previous in Forum: Solar Cell Breaks Conversion Record   Next in Forum: Transformer Design
Main Breaker Computation Needed
12/11/2006 5:19 PM
TO: all
Sir/Madam:
Can u explain to me please how compute the main breaker? Is there any rule of thumb?
I am just a beginner and Im still learning in the design stage. Please help me..
Thanks a lot.
c3p1124
Re: main breaker
12/11/2006 11:40 PM
Depends on what is in the circuit that is downstream. Any Motors? Are all of the circuits and devices individually protected? Transformers?
Re: main breaker
12/12/2006 6:07 PM
yes sir the devices are individually protected. In a certain panel, we have motors in it and on the other panels are molding machines (35KVA), press machines etc..
Example:
ckt 1 to ckt 8 are molding machines with 35 KVA at 3P and 200V. the demand factor is 70% . what should be the main breaker to be use?
Thank you for the reply...
Re: main breaker
12/12/2006 8:43 PM
In the case that each individual branch coming off the main disconnect is protected, I fuse (CB in your case) for the size of the disconnect. Otherwise I'd have to examine the entire system to see what kind of in-rush current I can expect. Unfortunately, its not as easy as a simple percentage.
Re: main breaker
12/13/2006 5:09 PM
thank u sir fro the response.. can u give e a sample for the computationof a certain panel board with 8 circuits containing molding machines with 35KVA,3P,200V with demand factor of 70%?
What should be the main breaker for the panel?
Popular Science - Weaponology - New Member Popular Science - Cosmology - New Member
Re: Main Breaker Computation Needed
12/13/2006 5:35 PM
As you seem to be working with an existing system, I would suggest
that you size the Main C.B. to protect the existing circuit.
(Thats the smallest unprotected element of same.)
You appear to have enough diversity to make inrush currents
a negligable factor unless there is one very large load or
a simultaneous start-up situation.
If your load is primarily motors, consider a time delay (K-5 or so) fuse
instead of a breaker. The interrupting current/price of unit is better
and a properly sized main shouldn't open unless you've goofed somewhere.
To properly calculate the size of a new service....
If you have to ask, you shouldn't be doing it but:
Take all your connected loads.
Apply a demand factor to each.
- (Judgement required. Note: Demand Load is NOT Service Factor)
Total the demand loads.
Add 125% of the largest starting current.
Add some room for expansion.
Total.
For interrupting rating required consult your utility for
avalable short circuit current. - Take the next largest
sized breaker rating, (unless its close, you do have motors).
If it's too close for comfort go up a notch.
12/13/2006 11:20 PM
This is c3p1124...
thank u sir i really appreciate ur reponse. That would help me..
God Bless..
Register to Reply 6 comments
Anonymous Poster (3); jstolaruk (2); Pragmatist (1)
You might be interested in: Circuit Breakers, Load Centers, Bus Plugs
