Previous in Forum: future field   Next in Forum: Claiming Damages from Your Local Utility
8 comments
Lawnmower Problems
08/03/2009 3:19 PM
Got a 96 lawnboy, model 10314, 4.75 hp and it has the famous lawnboy surge. It surges when coming off of a load. If I keep a load on the engine, it doesn't surge.
Many posts have suggested boring or replacing the jets with a larger diameter to overcome the EPA mandated leaning of the fuel mixture. Can anyone recommend a replacement model for the main and pilot jets? I've heard mikuni and suzuki make comparable jets but can't find the model numbers for this mower. Failing that, can anyone recommend the bit size to execute a re-boring?
Re: Lawnmower Problems
08/03/2009 4:45 PM
Lean fuel conditions certainly can cause a surge.
Before I change jetting, I would check the Governor. If this mower has a mechanical governor like my push mower, when they get worn or even dirty they can cause the engine to surge. It's like the throttle position gets "out of sink" with the RPM.
Many industrial engines have governors but I was surprised to find one on my push mower.
When it comes to drilling jets, I did this to a dirt bike that was very lean from the factory and achieved cleaner throttle response. Start with a very small increase in size. Remember, you are dealing with an increase in the cross sectional area so a small diameter increase will have a large affect.
Everything I know about opera I learned from Bugs Bunny
Good Answers: 97
08/03/2009 11:22 PM
Clean the air filter and maybe a slight restriction could cause a richer air/fuel mixture to occur
08/04/2009 1:22 AM
Very likely the Govenor tension spring needs to be attended to. Check attachment tab for bending or loose mount or interference by dirt or matter. Probably need to increase spring tension. Small amounts at a time when you establish if + / - tension is needed.
08/04/2009 1:02 PM
Well, if he is 96 hi's not a boy anymore, so try to be easy on him.
To avoid surges keep him busy.
I don't understand the last part of your post, if it was boring the first time, why do it again?
I'd try tiny increments on the drill bits, 'till desired performance is achieved.
Yahlasit
08/04/2009 5:41 PM
"if it was boring the first time, why do it again?"
-Guest
lol
i did somthing similar to this when i converted my propane BBQ to natural gas.
Bore the jet one drill size at a time. (ex. if a #12 bit barely fits in there just step it up to a #11). over boring it will obvesouly cause it to run rich and may cause loss of power and maby stalling all together.
good luck
08/04/2009 5:45 PM
I don't reccomend jet drilling. I have found that the govenor spring is usually the cause, from loose, dirt, bending or weak. On a mower I have, I intentionally caused this recover from really deep weeds and grass, allowing it to run wide open a bit longer.
Good Answers: 97
08/05/2009 1:16 AM
A shame lawnboy didn't keep the 2-stroke and handle the weeds with power while consuming less fuel...
08/05/2009 3:28 PM
Thank you all for the tips. I'll start with the least intrusive and give the carb a good cleaning with attention to the governor. If that fails, I'll move on to the pun-laden activity of boring the jets (my banjo playing usually does the trick).
Register to Reply 8 comments
Anonymous Poster (1); bwire (2); DaveB (1); luvin_the_rings (1); redleg (1); zoowho2 (2)
