Previous in Forum: Pavement Paint   Next in Forum: Chemical Composition of Reheater Pipe
Carbon Offsets and Trees
08/04/2009 2:35 AM
What is the equation(s) for calculating the carbon offset against Kwh of electricity produced by fossil fuels?
What is the equation for same against trees? does it make a difference which tree?
are pine trees better than deciduous?
Good Answers: 101
Re: Carbon Offsets and Trees
08/04/2009 10:38 PM
  1. Assuming that half the total mass of a tree is carbon, that means that tree contains that much carbon equivalent of CO2 removed from the atmosphere. If you know the formula of the fuel, you can work out a fairly accurate estimate.
  2. The best plants to grow are the very fast growing ones, as these will have the highest carbon uptake rate.
