Previous in Forum: How to select Engine alternator for on line UPS   Next in Forum: Hook Up document
12 comments
Circuit Breaker Amps
12/11/2006 11:03 PM
When using a 3 P CB, how many amps per Phase can you use?
630 kVA transformer using a 800 amp Main CB.
This is a 50hZ 415/240 V system, somewhere in Iraq.
smilne/ U.S. Army
Re: CIRCUIT BREAKER AMPS
12/12/2006 7:26 AM
what is CB?
Re: Circuit Breaker Amps
12/12/2006 2:24 PM
Any value your drill seargent tells you too! as long as it's less than the transformer current rating (876A at 415V OK) and less than or equal to the circuit breaker rating, which in this case is 800A per phase. Any more than 800A and you may trip the breaker out on current overload. Excessively high ambient temperatures may require derating of your 630kVA transformer and 800A CB to prevent overloading in the field.
12/12/2006 9:32 PM
hi, jak, whats CB? would you like tell me?
12/12/2006 9:54 PM
CB is short for Circuit Breaker, as in MCB (Miniature Circuit Breaker).
12/12/2006 11:47 PM
Thanks, figured it, damn electrical "engineers" want to put a 1000 per phase.
if i had to explain what cb was, thought you wouldn't know what i was talking about!
12/13/2006 12:48 PM
1000A per phase is to much for short-term or continuous operation, but for a very short time it may be ok (like to start up large equipment with large inrush current requirements). In the end it all comes down to what the CB can handle without overloading and tripping out (or getting damaged), and what volt drop is acceptable from the transformer when it is itself overload and its output voltage sags (but it is walking a very fine line between operational and disaster).
Popular Science - Weaponology - New Member Popular Science - Cosmology - New Member
12/13/2006 5:58 PM
It all depends. The T/F rates out 877A. @ 415 V. and 1518A. @ 240 V.
There might be an inrush consideration on the primary, and it's OK
to oversize that 125% or so if you overload protect the secondary.
Some utility type 'low Z` T/Fs do that.
Oil filled T/Fs ride through momentary overloads pretty well,
(thermal mass), but if that sucker is overheating, watch your ass!
12/13/2006 8:27 PM
Thank you Jack for your reply. now I think hte question is simple to solve.
different links get diffenrt current value.
12/13/2006 12:54 PM
In a transformer 630 KVA, 415 V you have 876.45 A per phase, you need a 1000 A, 3P, CB -Circuit Braeker for main protection to use the 100% of the transformer.
Good lock in Iraq
LJFF
12/13/2006 1:01 PM
with ambient temp's over 130 deg F, I derate to only 80% usage. transformers are oil filled.
12/15/2006 2:23 PM
Is fan cooling an option?
It can boost rating and help with high ambients.
130 F.?? ....in November??
12/13/2006 8:38 PM
Who supply them electric in iraq
Register to Reply 12 comments
Anonymous Poster (1); cnpower (4); jack of all trades (3); Pragmatist (2); smilne (2)
You might be interested in: KVA Meters, Power Frequency Converters, Radios
