Previous in Forum: Exhaust Gas Composition and HSD Fired Engines   Next in Forum: What are Mechanical Deaerators?
Calculating Thickness for Flat Plates
08/09/2009 12:06 AM
Hi,
Thickness of Flat plate calculation as per UG 34 of ASME VIII DIV1 UG 34 used to calculate the thickness plate . But How to find the thicknes if the plates are welded with stiffeners
RK
Good Answers: 97
Re: Calculating Thickness for Flat Plates
08/09/2009 10:49 PM
If a truck is overweight will reducing air pressure of tyres lower the vehicle weight?
Good Answers: 68
08/10/2009 2:02 PM
Hi wire,
How you doing?
Yes reducing the air in a tire will reduce the total weight of the vehicle.
You can say that a Litre of air weighs ~ 1 gram. But I am not sure how much air is in a tire. Depends on the size of the tire as well.
I would imagine the air in the truck 'tires' would weigh several Kilos? I have forgotten how the Math works, sorry. If you can tell me the area of the inside of a truck tire I think I can tell you the weigh, how about that? Better that a smack in the face with a wet fish? ;=)
Take care.
Good Answers: 97
08/12/2009 2:11 AM
I couldn't resist answering such an inane question without a little butter
Good Answers: 68
08/12/2009 3:04 AM
Hi wire,
Are you fine?
Yes the OP's request is not exactly the most readable piece on CR4. It is almost a statement really. I feel there should have been another bit that is missing?
Take care my friend.
08/09/2009 11:40 PM
You should calculate the section modulus with stiffners. Otherwise use STAAD or other softwares
08/10/2009 11:41 AM
Yes, I agree. Then determine what the equivalent thickness is w/o stiffners. Finally, check your stresses to makes sure they are acceptable.
Register to Reply 6 comments
b v rao (1); babybear (2); bwire (2); ccoop610 (1)
