Previous in Forum: Testing Earth Resistance   Next in Forum: Fault Current and Cable Selection
Graded Sensor
08/12/2009 6:02 AM
hi gents,
i saw in thermoking unit freezer unit 'MD300' three temperature sensors which control the defrost cycle. two called graded sensors and they used to check the discharge and return air temperature, the third one called ungraded sensor which is sensing the temperature of the evaporator coil.
my question is, what the meaning of graded and ungraded sensor? and can i fit graded instead of ungraded?
many thanks
Good Answers: 73
Re: Graded Sensor
08/12/2009 11:41 AM
I am just guessing, but it sounds like the "graded" sensor is a thermo-switch designed to open and close at some given temperature. The ungraded sensor, therefore, must be a thermocouple for measuring the actual temperature.
Mechanical devices are generally less expensive than electrical devices. But because mechanical devices have moving parts, they are subject to failure. All of the open circuit or shorted circuits I have ever seen are mechanical failures.
Re: Graded Sensor
08/12/2009 4:16 PM
My guess would actually be the opposite of the first answer. For graded is defined as arranged in a sequence of grades or ranks; "stratified areas of the distribution" http://www.google.com/url?&q=http://wordnetweb.princeton.edu/perl/webwn%3Fs%3Dgraded&ei=GyKDSp-2B6WEmQeTkpWjDg&sa=X&oi=define&ct=&cd=1&usg=AFQjCNGVJrBZeXQnq-mzzIgHtKeF2yaTBA
So the two sensors will measure the input and output relative temperature difference. While the other probe will just know if it's cold or not.
