Previous in Forum: Easeus Software?   Next in Forum: Macros in Microsoft Excel
Unable to Print
08/12/2009 8:56 PM
Dear, All
I have purchse printer. after install the driver. i restart my pc and try to print document but can't print.
please advsie
Re: can't print document
08/12/2009 10:36 PM
Try the printer manufacturer's support line, DUH
But it sounds like you have an ESO problem (Equipment Superior to Operator)
08/12/2009 10:50 PM
Thats just mean :)
Good Answers: 58
08/12/2009 10:59 PM
It's a PICNIC - Problem In Chair Not In Computer
08/13/2009 3:56 PM
PICNIC, I like it Got to remember that one.
Good Answers: 38
Re: Unable to Print
08/13/2009 8:05 AM
Hope you followed the manual! Usually you must install the software before hooking up the printer. When you plug the printer in it will be recognized by the system and the proper software will be loaded. Try removing the cables and software and then reboot. Install software again and then plug in printer or when prompted to. If you did this the first time, go to "install printer" and check to see if it is listed and set as default. If there and not printing follow directions to print a test page. If that fails there's a problem with the printer.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
Re: Unable to Print
08/13/2009 3:52 PM
Has the printer installed correctly? Can you see it in your list of printers on your computer?
Is it a special printer like a plotter which requires special setup?
Is the printer and/or computer an older model with limited 'plug-and-play' features requiring some manual setup during the printer installation process?
Please provide much more information as there are many possible reasons for this (include printer model and type, computer and operating system type and version).
Hobbies - Musician - Tube Amps Only Please!
Re: Unable to Print
11/06/2009 7:55 PM
Use the self test or this happened to me once take off the protective film from the brand new ink jets.
Regards, Maveric Manic - 'Knowledge is Power and Wisdom is knowing how to use it'
Anonymous Poster (1); charsley99 (1); jack of all trades (1); maveric_manic (1); redfred (2); The Prof (1)
