Previous in Forum: Corrosion Tendency Between Galvanized and Stainless Steel   Next in Forum: Search for PES copolymer supplier
Thermally Conducting Polymer Tubing
12/13/2006 7:56 PM
I am looking for a flexible polymer tubing that is a reasonable conductor of heat. Duty conditions:
  • Maximum temperature - 60 degrees Celsius;
  • Strongly ionic solution.
Hopefully nothing too exotic.
Regards
Re: Thermally Conducting Polymer Tubing
12/14/2006 10:47 PM
I would try those guys that build the floor heating systems they use some kind of plastic tubing in the floors, seems to last forever.
12/14/2006 11:10 PM
Thanks I'll give it a try.
12/15/2006 5:36 AM
Try http://www.usplastic.com/catalog/default.asp
They have tubing and also online technical assistance
1.1 billion people do not have safe drinking water
12/18/2006 6:52 AM
What do you mean with "Thermally Conductive"?
Typical plastics hace a thermal conductivity between .04 and 0.5
Higher numbers are called thermal conductive polymers.
Stainless steel has a K value of opprox 16. Carbon steel is approx 55 W/mK
Aluminium goes up to 200 where copper reaches 400.
You want a polymer for the fluid and the thermal conductivity for a cooling/heatup application?
solution: use sandwich pipes, they have a polymer inner liner with metal outside wall.
The thermal conductive paste that is used in electronic applicaiton have a conductivity between 1 and 5. Their main efficiency comes from the removal of the air gaps between the faces.
Register to Reply 4 comments
gregmac (1); Gwen.Stouthuysen (1); pilotcraig2001 (1); rustyh2o (1)
You might be interested in: Plastic Tubing, Rubber Tubing, Tubing
