Previous in Forum: P3 Ductal Design   Next in Forum: Dimension for 36" Flanges
Cylinder and Piston Clearance
08/14/2009 1:44 AM
Dear Freinds,
I want to ask a question about the standard clearance between cylinder and piston in hydraulic cylinder.
I want to design a hydraulic cylinder for a specific application and I'm not sure about the required clearance between cylinder bore and piston.
I appreciate if you could help me in this matter. Actually introducing a refrence or a book would be great.
Thanks in advanced,
Regards,
Mohsen
Re: Cylinder and Piston Clearance
08/14/2009 11:47 AM
We have a cylinder here that broke after a long time but it had .001 inch per side clearance.Now i would think the smaller you can make the clearance the better the cylinder would be as long as manufacturing can make it concentric and/or precise enough
Help me with the things i don`t know . I`ll try to help you with the things i do know and we`ll both get smarter
Location: 203 Madhu Industrial Estate, Mogra Lane, Andheri (E), Mumbai - 400 069. INDIA
08/15/2009 12:22 AM
Is this working as a pump or motor?
-Ray OMS, Mo: +91-99-307-14303, info@rayoms.com
08/15/2009 2:06 AM
Tolernace for Hyd. pistons is usually determined by the required pressure and the seals used in the piston. see http://www.simrit.de/web/public/home - they have in their catalog a comprehensive overview of various dynamic sealing methods.
Just note that the barrel (the piston's cylinder) is a standard product that can be bought with predefined tolerance of usually H8 to H6. the rod (moving part) can be bought with tolerances of class f7 or g7.
Hope this helps.
08/15/2009 4:37 AM
The clearance depends upon the pressure at which the hydraulic cylinder will be subjected to.
If the pressure is very high then the pressure will be acting radially on the area of clearance. if the clearance is more naturally the seals will be subjected to this pressure and resulting force.
For energising seals type the clearance kept is 0.2 mm i.e if the bore of the cylinder is 250 mm then the dia of the piston will be 249.8 mm.
you can go on the site of Bushak and shamban who are the leaders of the seals manufacturers and known to everybody who deals with hydraulic cylinders and seals.
regards
hari
"The person who makes a success of living is the one who sees his goal steadily and aims for it unswervingly." -- Cecil B. DeMille
Register to Reply 4 comments
hariagnihotri (1); MADMACHINE (1); oreng78 (1); Rajesh Shah (1)
