Previous in Forum: Masks for Swine Flu   Next in Forum: Critical Frequency of Vaccines
Cooling Tower Capacity Calculation for Milk Evaporator
08/16/2009 3:44 AM
dear guru ji
we have one evaporator with 5 effect and water evaporation capacity of 18500kg/hr
this for milk concentration may i know the capacity cooling tower in referegeration tonnage for cooling tower
sps sawhney
Re: Cooling Tower Capacity Calculation for Milk Evaporator
08/16/2009 11:17 PM
Dear Mr Sawhney
To calculate the cooling tower capacity, more information on the system in terms of evaporation per stage, evaporation conditions like vacuum in stages and type of preheater in use would be required.
Normally, for rough calculatins, at the maximum, its the heat load in the last calanderia generated in terms of vapour that you could consider as the equivalent refregration capacity
Sanjiv
08/16/2009 11:32 PM
dear sir
thanx for your reply the vapours to condenser from last effect shall be 1600kg/hr
temp shall be around 50c
08/17/2009 6:00 AM
To decide the capacity of cooling tower you have to understand the concept of heat rejection ratio. ( HRR). The loading on the condenser per unit refrigeration is known as heat rejection ratio. Water cooled condensers are used in conjunction with cooling tower. As a thumb rule the heat rejection ration varies form 1.25 to 1.35. You can check your condenser capacity my multiplying the T.R with HRR and accordingly select the cooling tower capacity.
08/18/2009 2:56 AM
Dear Mr Sawhney
Normally milk fed to the evaporator is in refregerated condition i.e at low temperature. This is heated in the preheater The energy transfer will be from the 1600 kg/hr of vapour coming and latent heat released due to condensation of this vapour. Depending upon the design of the preheater, part condensation of vapours will occur and the balance will be the load on the condensor.
This would determine the size of cooling tower.
For more details you could communicate with me on acmefil@mtnl.net,in
Sanjiv
Register to Reply 4 comments
acmefil (2); mrswamy (1); spssawhney (1)
