Previous in Forum: mechanical engineering   Next in Forum: MAWP VS Hydrostatic Test
08/18/2009 1:32 AM
we often use first and third angle projection in engineering drawings and we donot use second and fourth angle projections .why?
Good Answers: 101
Re: mechanical engineering
08/18/2009 3:09 AM
Because then you'll get plenty of hidden details. Try it yourself if you don't believe it.
08/18/2009 6:56 AM
if you use second and fourth angle projections, views will be over lapping each other.
08/18/2009 10:19 AM
First try to get the meaning why first angle is called first and third angle third.
Why not fifth, sixth... ?
Register to Reply 3 comments
Anonymous Poster (1); DVader1000 (1); imgkg (1)
